| New Reply |
Battery Life Cycle |
Share Thread | Thread Tools |
| Dec11-12, 07:42 AM | #1 |
Battery Life Cycle
Hello,
I have seen graphs of Battery's DoD (depth of discharge) vs Life Cycles. But at the same time, "life cycle" is defined as the no. of COMPLETE charge-discharge cycles that a battery can perform before its nominal capacity falls below 80% of its initial rated capacity. Here's the contradiction: From the definition, the term "life cycle" should only be valid for a DoD of 100% (or maybe 80%, whatever is the max. possible value). How can the battery's life be rated in terms of life cycle? In those graphs, does "life cycle" simply mean discharging to a specified amount (DoD) and then charging rather than COMPLETELY dscharging and charging the battery? |
| Dec14-12, 03:53 AM | #2 |
Yes, you discerned it correctly, the graph measures the life of a battery [defined as having worn to the point of 50% of nameplate capacity] vs the DoD [Depth of Discharge]
However, out in the real world, with scooter and power wheelchair batteries I see lifes much shorter than I would expect based on these graphs. I see commonly AGM batteries lasting 2-3 years. At one cycle per day, that is ~600-900 cycles. At a mere 10% DoD AGM batteries are expect to last {ON Average} over 2000 and Gel batters over 6000 over 10 years! This does not happen out in the real installations. Open Questions to me: 1. Why not? Is it something to do with the moving / shaking causing the premature battery failures. Is perhaps the quality / size of charger? Maybe the load current is higher in the scooters? Do not know. 2. The graphs of DoD all start at approximately 10% what happens at 5%? |
| Dec17-12, 06:13 PM | #3 |
There's an interesting article here that might illuminate what's going on. Apparently, lead-acid batteries, regardless of the type, have a fairly narrow charge-discharge window, and going outside it stresses them. That's why car makers are so interested in Li-ion, which has its own set of problems, of course.
| New Reply |
| Tags |
| battery life cycle |
| Thread Tools | |
Similar Threads for: Battery Life Cycle
| Battery AH and Deep Cycle type & Charger suitability | Electrical Engineering | 6 | ||
| Fatigue life cycle analysis | Classical Physics | 0 | ||
| Problems with a motor cycle battery! | General Engineering | 1 | ||
| Charging a deep cycle battery from cigarette lighter socket | Electrical Engineering | 3 | ||
| Product Life Cycle | General Discussion | 7 | ||
