New Reply
Verify about the solution of wave equation of potential.
Share Thread Thread Tools
Dec12-12, 08:25 PM   #1
I read in the book regarding a point charge at the origin where [itex]Q(t)= \rho_{(t)}Δv'\;[/itex]. The wave eq is.
[tex]\nabla^2V-\mu\epsilon\frac{\partial^2 V}{\partial t^2}= -\frac {\rho_v}{\epsilon}[/tex]
For point charge at origin, spherical coordinates are used where:
[tex] \nabla^2V=\frac 1 {R^2}\frac {\partial}{\partial R}\left( R^2 \frac {\partial V}{\partial R}\right)[/tex]
This is because point charge at origin, [itex]\frac {\partial}{\partial \theta} \hbox{ and }\; \frac {\partial}{\partial \phi}[/itex] are all zero.
My question is this:
The book then said EXCEPT AT THE ORIGIN, V satisfies the following homogeneous equation:
[tex]\frac 1 {R^2}\frac {\partial}{\partial R}\left( R^2 \frac {\partial V}{\partial R}\right)-\mu\epsilon \frac {\partial^2 V}{\partial t^2}=0[/tex]
The only reason I can think of why this equation has to exclude origin is because R=0 and origin and this won't work. Am I correct or there's another reason?
Thanks
Alan
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> Promising doped zirconia
>> New X-ray method shows how frog embryos could help thwart disease
>> Bringing life into focus
Dec12-12, 10:19 PM   #2
Recognitions:
Gold Membership Gold Member
Yep, you're right. Nothing complicated here.
Dec12-12, 10:57 PM   #3
Thanks
Alan
Dec13-12, 12:38 AM   #4
I have another question follow up with the original wave equation:
According to the book, to simplify this equation, Let:
[tex]V_{(R,t)}=\frac 1 R U_{(R,t)}[/tex]
This will reduce the wave equation to:
[tex]\frac {\partial^2U_{(R,t)}}{\partial R^2}-\mu\epsilon\frac {\partial^2U_{(R,t)}}{\partial t^2}=0[/tex]
One of the solution is [itex]U_{(R,t)}=f\left(t-\frac R {\mu\epsilon}\right)[/itex]
My question is I want to find the solution if U(R,t) is time harmonic which is a continuous sine wave. The book does not show the anything. So I am using the regular solution of time harmonic wave equation and using direction to be [itex]\hat R[/itex]. So the formula become:
[tex]\frac {\partial^2U_{(R,t)}}{\partial R^2}-\mu\epsilon\frac {\partial^2U_{(R,t)}}{\partial t^2}= \frac {\partial^2U_{(R,t)}}{\partial R^2}+\omega^2\mu\epsilon U= 0.[/tex]
[tex] δ^2=-\omega^2\mu\epsilon\;\Rightarrow\; \frac {\partial^2U_{(R,t)}}{\partial R^2}-δ^2 U= 0.[/tex]
This is a 2nd order ODE with constant coef and the solution is:
[tex]U_{(R,t)}= V_0^+ e^{-δ R}+V_0^- e^{δ R}[/tex]
For potential that reach to infinity space, there will be no reflection so the second term disappeared, whereby:
[tex]U_{(R,t)}= V_0^+ e^{-δ R}[/tex]
Do I get this right? This might look very obvious, but I am working on retarded potential and I am interpreting what the book don't say, I have to be careful to make sure I get everything right.
Thanks
Alan
Dec13-12, 12:43 AM   #5
[itex]\frac {\partial^2U_{(R,t)}}{\partial R^2}-\mu\epsilon\frac {\partial^2U_{(R,t)}}{\partial t^2}= \frac {\partial^2U_{(R,t)}}{\partial R^2}+\omega^2\mu\epsilon U= 0.[/itex]
just from the last in it you can write the periodic solution.Don't substitute any δ after.
Dec13-12, 12:47 AM   #6
Quote by andrien View Post
Thanks for the reply, I just finished updating the last post, please take a look again. The reason I use δ is because this will be used in phasor form which is going to be in form of:
[tex]U_{(R,t)}= V_0^+ e^{\alpha R} e^{j\beta R}\; \hbox { where } δ=\alpha + j\beta[/tex]
Dec13-12, 12:53 AM   #7
a plus sign before ω2 in eqn is necessary for periodic solution.First write solution in terms of ω and then introduce other definitions.
Dec13-12, 02:33 AM   #8
This is because for lossy dielectric medium ε=ε'+jε'' therefore [itex] δ=j\omega \sqrt{\mu(ε'+jε'')}[/itex] is a complex number where [itex]δ=\alpha + j \beta[/itex]. Solution of:
[tex]\frac {\partial ^2 U}{\partial R^2} -δ^2U=0 \hbox { is }\; U_{(R,t)}= U_0^+ e^{-δR}\;=\; U_0^+ e^{-\alpha R} e^{-j\beta R}[/tex]
This is a decay periodic function.
For lossless, we use [itex] k=\omega\sqrt{\mu\epsilon}\hbox { where ε is real.}[/itex]
Then
[tex]\frac {\partial ^2 U}{\partial R^2} +k^2U=0 \hbox { is }\; U_{(R,t)}= U_0^+ e^{-jkR}[/tex]
Actually because you brought this up, I dig deep into this and answer the question why the books use δ for lossy media and k for lossless media. I never quite get this all these years until now.
Dec13-12, 07:11 AM   #9
that is why it is better to go with + sign.but it is ok,now.In case,ε is complex it is still possible to define things after.But you already got it.
Dec13-12, 02:52 PM   #10
Thanks.
New Reply
Thread Tools
Similar Threads for: Verify about the solution of wave equation of potential.
Thread Forum Replies
Solutions to 2D wave equation using 1D equation solution. Calculus & Beyond Homework 6
How to find verify solution to differential equation Calculus & Beyond Homework 5
Wave Equation in 1-d Proof/Verify Introductory Physics Homework 2
Verify that the function U is a solution for Laplace Equation. Calculus & Beyond Homework 2
Verify that this is the solution to an ordinary differential equation Calculus & Beyond Homework 8
