Learning Probability: Solving a Density Function Problem
  • Context: Undergrad
  • Thread starter Thread starter Niels
    Probability
The discussion focuses on calculating probabilities using a given density function, f(x,y) = x^2 + xy/3, defined for 0 Y), Prob(Y < 1/2 and X < 1/2), and Prob(X + Y < 1). The solutions involve double integrals over defined regions, specifically integrating the density function to find the desired probabilities.
  • Understanding of probability theory and random variables
  • Familiarity with double integrals in multiple-variable calculus
  • Knowledge of density functions and their applications
  • Ability to visualize geometric regions defined by inequalities
  • Study the concept of joint probability distributions and their properties
  • Learn how to perform double integrals over specified regions
  • Explore the use of geometric interpretations in probability problems
  • Investigate the implications of conditional probabilities in multiple dimensions
This discussion is beneficial for students learning probability, educators teaching probability concepts, and anyone interested in applying calculus to solve probability problems involving multiple variables.
Niels
I'm trying to learn probability on my own and I'm stuck.
My multiple-variable-calculus is not so strong so the following problem got me stuck.
I have density function
f(x,y) = x^2 + xy/3 for 0<x<1; 0<y<2 otherwise 0
And I need to calculate Prob(X > Y). X and Y are random variables.
I know how to do Prob(X <= 0.5) etc.
Also would be nice if someone could explain Prob(Y < 1/2 and X < 1/2) and
Prob(X+Y < 1)
Thanks
/Niels
Just to make sure, this is just integrating over all values of Y, such that X <= 0.5, which is a rectangle.
Similarly, this is an integration of the density function over the region where Y < 1/2 and X < 1/2. This is a square of sidelength 1/2 with one corner at the origin. It is a double integral that can be written as:
[tex]\int_0^{\frac{1}{2}} \int_0^{\frac{1}{2}} f(x,y) dy dx[/tex]
Do you know how to find P(X<1/2 OR Y<1/2) ?
Niels said:
and
Prob(X+Y < 1)
If you cannot picture the region, rewrite it in a friendlier form; ie., Y < -X + 1. You're then integrating the density function for all points below the line y = -x + 1. This integral can be written:
[tex]\int_0^1 \int_0^{-x+1} f(x,y) dy dx[/tex]
So your original problem, P(Y<X) is just the set of points below the line y=x.
thank you!
