Metal Composition of Motorcycle Chassis
The discussion centers on the materials and construction methods used in the chassis of motorcycles, specifically the Yamaha YZF-R1 and Yamaha Raptor 700R. Participants explore the types of metals, whether the chassis is solid or hollow, and the manufacturing processes involved.
  • One participant inquires about the specific metals used in the chassis of the Yamaha YZF-R1 and Raptor 700R, questioning if they are solid or hollow and whether they are cast or extruded.
  • Another participant notes that modern chassis designs often incorporate a mix of materials, including cast, forged, and extruded aluminum.
  • A participant mentions that 4130 Chrome-Moly is typically used in custom builds, while suggesting that mild steel tubing may be used in stock factory models.
  • It is stated that the primary frame of the YZF-R1 is made of aluminum, which is welded from castings and extrusions, and that the rear sub-frame is made of cast magnesium.
There are multiple competing views regarding the materials and construction methods used in motorcycle chassis, and the discussion remains unresolved on certain specifics.
Participants have not fully defined the terms used, such as "solid" or "hollow," and there may be assumptions about the types of builds being referenced (custom vs. stock). The discussion does not clarify the extent to which different materials are used across various models.
mymachine
Hello guys,
I wonder and would like to know what kind of metal to made a motorcycle chassis such as Yamaha YZF-R1 and Yamaha Raptor 700R?
Is it solid or hollow?
Is it cast or extrude?
Thank you
MyMachine
Modern chassis designs use a variety of materials and processes. It is quite common to find cast and/or forged sections joined to extruded aluminum.
Google will find you myriad references to more specific information.
4130 Chrome-Moly is usually used in custom builds and i suspect mild steel tubing is used on stock factory rides
The YZF-R1 primary frame is aluminum (welded together from castings and extrusions), with a cast magnesium rear sub-frame.
