Does My Triple Integral for a Cylinder's Volume Bounded by Planes Seem Correct?
  • Thread starter Thread starter ninjacookies
    Integral
The original poster attempts to find the volume of a solid bounded by a cylinder defined by the equation x² + y² = 25, the plane x + y + z = 8, and the xy-plane. They have set up a triple integral using cylindrical coordinates to compute this volume.
  • Exploratory, Assumption checking
  • Participants discuss the setup of the integral and the interpretation of the geometric shapes involved, including the nature of the cylinder and the planes. There are questions about whether the original poster's assumptions about the shapes and their intersections are valid.
Some participants have checked the original poster's integration and expressed confidence in the calculations. However, there is ongoing exploration of the geometric interpretations and the implications of symmetry in the problem.
There are discussions about the definitions of the shapes involved, particularly whether the solid is indeed a cylinder and the nature of the planes' intersections. The original poster grapples with the apparent coincidence of their calculated volume matching that of a regular cylinder, raising questions about the geometry of the situation.
ninjacookies
I'm supposed to find the volume of the solid bounded by the cylinder x^2+ y^2 =25, the plane x + y + z =8 and the xy plane.
So I decided to use cylindrical coordinates, in which E is bounded by the cylinder r=5, the plane z = 8 - y -z = 8 - r cos(theta) - r sin(theta) , and theta goes from 0 to 2pi
So my integration was setup as follows:
[tex]\int_{0}^{2pi} \int_{0}^{5} \int_{0}^{8-rcos \theta - rsin \theta} \ r dzdrd\theta[/tex]
and after about a half page of calculations, I ended up with the answer 200pi
Does this answer seem reasonable? I double checked my calculations and they seem all correct...is my integration setup correctly? The reason I'm asking is because the volume of a regular cylinder is
V=pi r^2 h , and in this situation the volume of the cylinder itself would be V=pi (5)^2 (8) = 200pi
so my answer of 200pi kinda confuses me since the cylinder I'm calculating is bounded by a the two planes x+y+z =8 and the xy plane.
Or is this just symmetry and coincidence that they're both equal?
Thanks
First of all I'm not sure it is a cylinder.You've the equation of a circle.The 2 planes ("xy" and "x+y+z=8") are not parallel.If they were,u may have made the assumption that the base area is 25pi and the height would be 8 and then the volume would be 8*25pi=200pi...
I'm sure that the answer is correct (i've chacked your integration),for symmetry reasons...
Daniel.
Daniel.
Thanks much Daniel, greatly appreciated. I assumed it was a cylinder because the problem specifically stated it is a cylinder, so I used cylindrical coordinates accordingly since I thought that'd be the best way to go about it. I graphed the whole thing and I understand that the xy plane and x+y+z =8 form a three dimensional pyramid with xy as the base and the second plane with end points (0,0,8) (8,0,0) and (0,8,0) ...and then the cylinder being cut through by the pyramid. So my integration and answer all seem correct? I just want to make sure I didn't make a fatal error in my setup. Thanks again
It's important that the intersection between the x+y+z=8 plane & the cylinder is symmetrical wrt the plane z=8...
Daniel.
Daniel.
Is there any easy way to determine this? I'm assuming the interesection is symmetrical, since the pyramid has length 8 on all sides and the cylinder is uniform. Though I could be wrong...
