Potential Energy vs. Position Graph
The discussion revolves around the characteristics of equilibrium points in potential energy vs. position graphs, specifically focusing on the nature of relative minima and their classification as stable, unstable, or neutral equilibrium points. Participants also explore concepts related to kinetic energy in equilibrium states and the implications of the slope of the potential energy graph as force.
  • Exploratory, Technical explanation, Debate/contested
  • Some participants question whether a relative minimum in a potential energy graph always corresponds to a stable equilibrium, seeking clarification on the definitions of stable, unstable, and neutral equilibrium points.
  • Others discuss the concept of asymptotic stability as mentioned in an article, with varying interpretations of its meaning in the context of equilibrium.
  • A participant suggests that stable equilibrium is characterized by a ball remaining in a valley unless disturbed strongly, while another notes that kinetic energy can exist in stable equilibrium, raising questions about the conditions under which this occurs.
  • There is a discussion about the relationship between the slope of the potential energy graph and force, with inquiries into why the force must be the negative of the slope.
Participants express differing views on the relationship between relative minima and stable equilibrium, as well as the role of kinetic energy in stable states. The discussion remains unresolved regarding the definitions and implications of these concepts.
Participants acknowledge that stable equilibrium typically assumes low or negligible kinetic energy, but they also explore scenarios where kinetic energy is present, leading to further questions about the nature of equilibrium.
Bashyboy
I attached a graph of a potential energy vs. position graph. My question is, the relative minimum is characterized as a equilibrium point, but what is, specifically, is this type of equilibrium point--a stable, unstable, or neutral one?
I am reading this article, http://home.comcast.net/~sharov/PopEcol/lec9/equilib.html , regarding potential energy and equilibrium, and I am rather bewildered by the article's use of the word asymptote. The sentence containing it is, "An equilibrium is considered stable (for simplicity we will consider asymptotic stability only)..." I tried to look up the word in the dictionary, but it came up with only the mathematical definition. What do they mean by asymptotic stability?
Stable - if you were to set a ball there it would tend to stay there unless disturbed strongly enough to push it "out of the valley".
In this context, asymptotic stability means that if you drop a little ball into the "valley", it will roll back and forth around the bottom for a while before it comes to rest at the bottom.
So, does a relative minimum always correspond to a stable equilibrium? At this point, the system possesses kinetic energy and potential energy, but that seems odd. Could you give me an example of a system that is in stable equilibrium that possesses kinetic energy and potential energy? Also, I understand that the slope of the potential energy vs. position graph is force, but why does it have to be the negative of the slope in order for it to be force?
In normal usage, stable equilibrium assumes there is little or no KE. If a body enters that position with significant KE, it might very well fail to stay there. But that does not alter the fact that it would have stayed there if the KE had been sufficiently small. If sufficiently small is still nonzero, it is a position of stable equilibrium.
  • · Replies 18 ·
