Solving Incline Forces: Acceleration, Tension, and Speed Calculations
  • Thread starter Thread starter Valerie
    Forces
This discussion focuses on solving incline force problems involving acceleration, tension, and speed calculations for two connected masses over a frictionless pulley. In the first scenario with masses m1=2.00 kg and m2=6.00 kg at an incline of 55 degrees, the acceleration of m1 is calculated as 8.43 m/s², while m2 has an acceleration of 3.40 m/s². The tension in the string for m1 is 16.85 N and for m2 is 50.55 N. In the second scenario with masses 3.50 kg and 8.00 kg at an incline of 35 degrees, similar calculations apply to find acceleration and tension.
  • Understanding of Newton's second law (F=ma)
  • Knowledge of trigonometric functions (sine and cosine)
  • Familiarity with basic physics concepts of tension and acceleration
  • Ability to perform calculations involving gravitational force (g=9.8 m/s²)
  • Learn how to apply Newton's laws to different pulley systems
  • Study the effects of friction on incline problems
  • Explore advanced topics in dynamics, such as non-constant acceleration
  • Investigate real-world applications of tension and acceleration in engineering
Physics students, educators, and anyone interested in mastering mechanics related to forces on inclined planes and pulley systems.
Valerie
I need your help on these guys!
1) Two objects are connected by a light string that passes over a frictionless pulley. If the incline is frictionless and m1=2.00 kg, m2=6.00kg and theta=55.0 degrees, a)find the acceleration of the objects. b)the tension in the string and c) the speed of each object at 2.00 s after being released from rest. (note: both of the objects are over a pulley, on an incline.
2)Two blocks of mass 3.50kg and 8.00kg are connected by a massless string passing over a frictionless pulley. The inclines are frictionless. Find a) the magnitude of acceleration of each block and b)the tension in the string. (theta for each side=35 degrees)
I would appreciate if someone could explain them to me please. Thank you!:smile:
" both of the objects are over a pulley, on an incline." Does that mean both objects are sitting on the same incline or is one on the incline and the other hanging? Where is the pulley in relation to the incline- and where is angle theta?
1) To solve for the acceleration in this scenario, we can use Newton's second law: F=ma. We will need to consider the forces acting on each object separately. For m1, there is only one force acting on it, which is the tension in the string pulling it down the incline. This force can be calculated using the formula F=mg*sin(theta), where g is the acceleration due to gravity (9.8 m/s^2) and theta is the angle of the incline. So for m1, the force is F=2.00*9.8*sin(55)=16.85 N. We can then plug this into the formula F=ma to solve for the acceleration of m1: a=F/m=16.85/2.00=8.43 m/s^2.
For m2, there are two forces acting on it: the tension in the string pulling it up the incline, and its weight pulling it down. We can use the same formula as above to calculate the tension in the string, which is F=6.00*9.8*sin(55)=50.55 N. The weight of m2 is F=6.00*9.8*cos(55)=30.17 N. To find the net force on m2, we can subtract the weight from the tension: 50.55-30.17=20.38 N. Plugging this into F=ma, we get a=20.38/6.00=3.40 m/s^2.
To find the speed of each object at 2.00 s, we can use the formula v=u+at, where u is the initial velocity (which is 0 since they start at rest), a is the acceleration we just calculated, and t is the time (2.00 s). For m1: v=0+8.43*2.00=16.86 m/s. For m2: v=0+3.40*2.00=6.80 m/s.
2) In this scenario, we can use the same approach as above to solve for the acceleration and tension. For the 3.50 kg block, the only force acting on it is the tension in the string pulling it down the incline. This can be calculated using the formula F=mg*sin(theta), where g is the acceleration due to gravity (9.
  • · Replies 29 ·
