Calculating the Coulomb Force between 2 charges in space
The discussion revolves around calculating the Coulomb force between two charges in the presence of dielectric materials. Participants explore two specific problems involving the arrangement of dielectric slabs between the charges and the implications for the effective dielectric constant.
  • Vivek presents a problem involving two charges in a dielectric medium and seeks to find the force when a dielectric slab is introduced between them.
  • Vivek expresses uncertainty about how to approach a second problem involving two dielectric slabs of different thicknesses and constants.
  • Vivek questions the possibility of finding an effective dielectric constant for the two slabs and references a formula he encountered, though he struggles to derive it.
  • Reilly Atkinson suggests that both problems are complex and may require advanced techniques such as Fourier Bessel integrals or boundary value problem solutions.
  • Vivek reflects on the difficulty of the problems, noting their context in an engineering entrance exam that does not cover advanced topics like Fourier-Bessel integrals or Maxwell's equations.
  • Vivek discusses the potential application of the effective dielectric equation to point charges and expresses uncertainty about its validity in this context.
  • Vivek also mentions a related problem involving induced charge on a conducting plate near a point charge and seeks resources for learning about the method of images.
Participants do not reach a consensus on the solutions to the problems presented. There are multiple competing views on how to approach the calculations and the validity of certain assumptions, particularly regarding the effective dielectric constant.
Participants acknowledge limitations in their understanding and the complexity of the problems, particularly in relation to the mathematical techniques required. There is also a noted dependence on the definitions and assumptions regarding the arrangement of dielectric materials.
This discussion may be useful for students preparing for engineering entrance exams, individuals interested in electrostatics, and those seeking to understand the implications of dielectric materials in physics problems.
maverick280857
Hi
Here is an interesting problem which I have been trying to solve. For convienience of discussion, I have broken it into parts to show where I get stuck:
Two charges [itex]Q_{1}[/itex] and [itex]Q_{2}[/itex] are kept in space at a distance r from each other in a medium of dielectric constant K. The force between them is given by
[tex]F = \frac{1}{4\pi\epsilon_{0}K}\frac{Q_{1}Q_{2}}{r^2}[/tex]
Problem #1: Now if instead of the original dielectric medium we have a slab of dielectric constant K and width r/2 placed somewhere between the two charges, then find the force between the two charges (this is not homework so I guess its in the right place).
Problem #2 (This is what I could not do): The space between the two charges (i.e. r) is filled with two dielectric slabs of thickness [itex]d_{1}[/itex] and [itex]d_{2}[/itex] and dielectric constants [itex]K_{1}[/itex] and [itex]K_{2}[/itex] such that [itex]d_{1}+d_{2} = d[/itex].
My reasoning (so far) for the first problem: If two charges are kept at a distance r in a medium of dielectric constant K then they must be kept in air at a separation = [itex]r\sqrt{K}[/itex] in air to keep the force of interaction constant. This gives the effective distance they must be placed at in air, as [itex]\frac{r}{2} + \frac{r\sqrt{K}}{k}[/itex]. How do I use this for the second problem?
Advice/help is greatly appreciated.
Thanks and cheers
vivek
TO add to my previous post:
Is it possible to find an effective dielectric constant in such a case?
I read somewhere that I could do this using:
[tex]\frac{d_{1}+d_{2}}{K} = \frac{d_1}{k_1}+\frac{d_2}{k_2}[/tex]
Obvious as this equation seems, I can't seem to extract anything out of it let alone derive it.
Thanks,
vivek
To everyone: a reminder...
To the Moderator: please relocate this if you feel the same.
To derive this equation for the effective dielectric constant of the two slabs, consider two parallel plate capacitors in series:
[tex]1/C = 1/C_1 + 1/C_2[/tex]
[tex]1/(k_{eff}/d) = 1/(k_1/d_1) + 1/(k_2/d_2)[/tex]
... etc ([itex]d = d_1 + d_2[/itex])
Are the slabs of dielectric stacked on top of one another or is it that the capacitor has a dielectric [itex]K_1[/itex] on the left half and a dielectric [itex]K_2[/itex] on the right half?
Maverick... Both problems 1 and 2 are difficult, and require either an infinite series of images, or direct solutions of the boundary value problem in terms of Fourier Bessel integrals. Prob 1 can be found in Symthe's Static and Dynamic Electricity, Chapter 5, Section 5.303 Point Charge and Dialectric Plate. Prob 2. is, or should be, a relatively straightforward extension of prob 1.
Regards,
Reilly Atkinson
Thanks a lot Doc Al, Corneo and reilly...
I didn't realize that problem 2 would be so tough (but that's because I already knew the governing equation...maybe?). This is because they were posed as prospective problems for an engineering entrance test (called the Joint Entrance Examination in India) which requires a background of very basic physics and electrodynamics (no Fourier-Bessel Integrals, Maxwell's Equations, PDEs, images, Laplace/Poisson equations, etc--just total derivatives and an extension of the theory mentioned in books like Crane,Zemansky/Sears, etc.) I suppose I need to know much more physics/mathematics to be able to derive these equations.
Doc, I could do the effective dielectric derivation for a parallel plate capacitor but I am not sure if I can use it for two point charges. I mean, you have two point charges in space and the space between them is filled with two dielectric slabs (only the width of which is given). I am not sure if we can use the idea of induced charge in much the same way as we set up equations for a parallel plate capacitor using Gauss's Theorem.
If however, I assume that the effective dielectric equation mentioned in my third post is correct then the problem is solved (though I don't think so as I don't know where the equation came from, for the point charges). :smile:
A related problem is (which I think can be done using the images method) to find the induced charge on a conducting plate when placed near a point charge. I would be grateful if you folks could point me to some book or internet resource where I can learn some basic stuff about the method of images to be able to apply it to relatively simple situations. I have been reading Cheng but as I have little time left for my exams, I cannot really start from scratch and understand all the mathematics required for a proper treatment of the subject.
Thanks and cheers,
Vivek
  • · Replies 44 ·
  • · Replies 19 ·
