Newton's Cradle 2 Balls: What Happens When You Release?
  • Context: Undergrad
  • Thread starter Thread starter skydivephil
    Balls Newtons
The discussion revolves around the mechanics of a Newton's Cradle, specifically examining the behavior of the system when two balls are released simultaneously from one end. Participants explore the principles of conservation of momentum and energy, the nature of collisions, and the implications of these principles on the observed outcomes in the cradle.
  • One participant describes the expected behavior of the cradle when one ball is released, noting that one ball oscillates on the opposite side, but questions why two balls rise when two are released.
  • Another participant suggests working out the one ball case mathematically to understand the mechanics better.
  • Some participants mention conservation of energy and momentum as key principles, assuming equal mass for all balls.
  • There is a discussion about whether energy is transferred into a higher arc or if it behaves differently with two balls released.
  • A participant references a Wikipedia analysis, proposing that the two-ball case can be treated as a single ball hitting stationary ones, followed by another ball hitting the first one.
  • One participant argues that conservation laws do not limit the outcome to a single scenario, noting that released balls could bounce back slightly while still conserving momentum and energy.
  • Another participant introduces the idea that the balls are not perfectly rigid and that the "information" about collisions takes time to travel, suggesting a model involving single-pair collisions to explain the observed behavior.
  • Several participants assert that the cradle demonstrates conservation of momentum, with claims that the number of balls released equals the number of balls that come out, although they acknowledge that this does not solely rely on momentum conservation.
  • One participant emphasizes the need for experimental confirmation of the outcomes, suggesting that various combinations should be tested.
Participants generally agree on the observed behavior of the cradle when releasing multiple balls, but there is disagreement regarding the sufficiency of conservation of momentum alone to explain the outcomes. Some participants challenge the notion that momentum conservation is the only principle at play, indicating that additional factors, such as energy considerations, must be taken into account.
There are unresolved aspects regarding the assumptions made about the rigidity of the balls, the nature of collisions, and the mathematical modeling of the system. The discussion reflects varying interpretations of how these factors influence the behavior of the cradle.
skydivephil
We have a Newtons cradle , when you let go of one ball at one end you know what happens. Rlease one ball and the other side has a ball osciallte.
But if you release two balls (with a 5 ball cradle) , why is that two balls on the other side of the middle ball also rise in response. How does the system "Know" we have released two balls? Why doesn the other side just have one ball oscillating higher?
Can you work out the one ball case mathematically?
Conservation of energy and momentum. This is, of course, assuming that all balls have the same mass.
Well i get that the system is conserving the momentum and tranferring the energy along the lines of balls, but I don't understand why doesn't the energy just get transferred into a higher arc?
Have you tried wikipedia? It's got actually quite a good analysis of the subject.
Long story short, you can treat the two-ball case as if it was a single ball hitting the stationary ones, and then another one hitting the now-stationary first one.
Conservation of momentum and energy don't limit the result to just one possible outcome. For example, the released balls could end up bouncing backwards a bit and momentum and energy will be conserved. In the real world, a single released ball will bounce backwards at a small velocity (slight rebound). Link to a website with the details:
http://www.lhup.edu/~dsimanek/scenario/cradle.htm
Keep in mind two things: (1) the balls are not perfectly rigid but deform slightly during a collision, and (2) the "information" about the collision takes some time to travel from one ball to the next.
You can rethink what is going on if you imagine there is a very small gap between each pair of adjacent balls, including the two balls that are initially raised and simultaneously released. It's not a perfect model, but it builds a time delay into the system that would account for the time it takes balls to deform during a collision, or the time it takes the deformed wave to travel across the diameter of a ball.
Thought about this way, every collision involves only two balls (of equal mass), one moving and one at rest. See if you can work out the entire process of these single-pair collisions, and what finally happens with the two balls at the other end. (Hint: this model predicts exactly what is observed. :smile:)
Newton's cradle is usually used to demonstrate conservation of momentum.
This means that the momentum IN will equal the momentum OUT.
2 balls In will give 2 balls OUT
3 balls in will give 3 balls OUT
4 balls IN will give 4 balls OUT
5 balls IN will give 5 balls OUT (think about it !)
Try all combinations !
If you could not see the 5 balls (a piece of card can be used to hide them) and you pretend that you can't hear any collision you would not realize that a collision had occurred.
The fact that collisions may not be perfectly elastic complicates matters slightly (KE is not conserved) but can be safely ignored if all you want is to use the cradle for what it was intended to show.
Not from conservation of momentum alone. You could get 1 ball out at twice the speed of the 2 balls in, and you'd still conserve momentum.
However, this would require an increase in kinetic energy.
The conventional 'Newtons cradle' consists of 5 freely hanging steel balls in a frame of some sort.
My list of possible collisions is based on the given number of balls pulled together to one side and released together.
I have never seen 2 balls (or 3 or 4 or5) released produce anything other than 2 (or 3 or 4 or 5) balls come out of the other side.
This is very easy to confirm by experiment. You should try this before making any unequivocal comment.
I am sure that with some trickery, like sticking balls together you can get other combinations.
With no such trickery I think that I can guarantee that number IN = number OUT
There are many possible combinations that should be tried...
2 in from 1 side, 1 in from the other side...I won't list them all
Nobody is disputing that. Certainly I don't.
My comment was directed at the statement that we only need conservation of momentum, and nothing else, to completely explain what we all agree happens in reality.
Consider this scenario, which we agree does NOT happen:
2 balls in → 1 ball, at TWICE the speed, out.​
Fact: the above does NOT happen.
Fact: momentum is conserved in the above scenario
  • · Replies 64 ·
  • · Replies 53 ·
  • · Replies 84 ·
  • · Replies 45 ·
