SIMPLE force of friction question
The force of friction acting on a 15kg wagon being pulled with a 5N force at a 45-degree angle is -3.54N. To determine the frictional force, it is essential to understand that the normal force is derived from the weight of the wagon and the vertical component of the applied force. The problem can be simplified by recognizing that if the wagon is moving at a constant speed, the frictional force equals the horizontal component of the applied force, which is 5N multiplied by the cosine of 45 degrees. Thus, the weight of the wagon is relevant for calculating the normal force but not directly needed for determining the frictional force when constant speed is maintained.
  • Understanding of Newton's laws of motion
  • Knowledge of vector components in physics
  • Familiarity with the concept of normal force
  • Basic grasp of frictional force calculations
  • Study the calculation of normal force in inclined planes
  • Learn about the coefficient of friction and its applications
  • Explore vector resolution techniques in physics
  • Investigate the relationship between force, mass, and acceleration
Students in physics, educators teaching mechanics, and anyone interested in understanding the dynamics of forces and friction in practical scenarios.
helix
You are pulling a 15kg wagon by the handle (with 5N of force) forming a 45 degree angle level to the ground. What is the force of friction on the wagon?
Okay, is it just me, or does this problem seem way to easy to be worth 100 pts?
It's -3.54N, right? Is the weight of the wagon irrelevant?
Thanks!
To find the fricational force you need to know the coefficient of friction ([mu]). Then the frictional force = [mu] * normal (N) . The normal force is perpendicular to the plane which the object is on and equal to the y component of the weight in your case.
I can't stress enough how helpful a picture is. Label all the forces and draw their components. Once you are confident that the picture is correct then procede to sum the forces in the x and y and/or z direction, setting the lefthand side to either 0 or m*a.
No, you do not need to know the coefficient of friction or the weight of the bag.
Assuming that the woman is pulling the bag at a constant speed, the horizontal acceleration is 0 and there must be no net horizontal force. The friction force is exactly the horizontal component of force the woman is applying and oppositely directed.
I get exactly the same answer you do. Since you are told what the mass of the bag is, you could calculate its weight and then find the coefficient of friction from the information given.
  • · Replies 23 ·
11K
  • · Replies 24 ·
9K
