New Reply
Design a condenser of a steam power plant
Share Thread Thread Tools
Dec23-12, 04:14 PM   #1
This question is from my textbook: Thermodynamics an Engineering Approach 7ed SI Units, cengel. It is problem 10-129 and I can't seem to figure it out.
Design the condenser of a steam power plant that has a thermal efficiency of 40 percent and generates 10 MW of net electric power. Steam enters the condenser as saturated vapour at 10kPa, and it is to be condensed outside horizontal tubes through which cooling water from a nearby river flows. The temperature rise of the cooling water is limited 8 degC, and the velocity of the cooling water in the pipes is limited to 6 m/s to keep the pressure drop at an acceptable level. From prior experience, the average heat flux based on the outer surface of the tubes can be taken to be 12,000 W/m^2. Specify the pipe diameter, total pipe length and the arrangement of the pipes to minimize the condenser volume.
I found h4 and h1 from the steam property tables and I know that the surface area will be dependent on the heat flow out of the system divide by the heat flux per m^2 but cant seem to put it all together any help is appreciated.
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> As chaos celebrates its 50th birthday, biophysicist develops a new method to visualize it
>> Novel features of helium-3 superfluidity discovered with new SQUID detector chip
>> Physics of 'green waves' could make city traffic flow more smoothly
Dec23-12, 04:35 PM   #2
mfb
Mentor
What are h4 and h1?
Based on your numbers, you can calculate the steam flow (in m^3/s) and the total surface of the pipes.
For a pipe with diameter d and length l, you can calculate the surface of this pipe and the power - and find a constraint for the length (or diameter) based on the flow velocity and maximal temperature difference.
This just leaves the question how exactly you want to design the whole thing.
New Reply
Thread Tools
Similar Threads for: Design a condenser of a steam power plant
Thread Forum Replies
Steam power plant design Mechanical Engineering 1
steam power plant cycle design, Mollier Diagram help Engineering, Comp Sci, & Technology Homework 5
steam power plant cycle design, Mollier Diagram help Mechanical Engineering 0
Steam Power Plant Engineering, Comp Sci, & Technology Homework 2
