The continuity property of probability
The continuity property of probability states that for an increasing or decreasing sequence of events \(E_{n}\), the limit as \(n\) approaches infinity of the probability \(P(E_{n})\) equals the probability of the limit of the events, expressed as \(P(\lim_{n\rightarrow\infty} E_{n})\). This property requires proof because the left side involves the limit of probabilities, while the right side evaluates a probability on a limit of sets. The distinction is crucial, particularly when considering sequences that converge to the empty set, which affects the convergence of probabilities. Understanding this property is essential for grasping foundational concepts in probability theory.
  • Understanding of probability theory fundamentals
  • Familiarity with limits in mathematical analysis
  • Knowledge of sequences and their convergence properties
  • Basic concepts of set theory
  • Study the proof of the continuity property of probability in detail
  • Explore the implications of the Borel-Cantelli lemma in probability theory
  • Learn about the differences between pointwise and uniform convergence of sequences
  • Investigate the role of sigma-algebras in defining limits of sets
Mathematicians, statisticians, and students of probability theory who seek a deeper understanding of the continuity property and its implications in probability calculations and proofs.
Appleton
If (E[itex]_{n}[/itex])) is either an increasing or decreasing sequence of events, then
lim n[itex]\rightarrow[/itex]∞ P(E[itex]_{n}[/itex]) = P(lim n[itex]\rightarrow[/itex]∞ (E[itex]_{n}[/itex]))
This seems to be saying that the limit as n goes to infinity of the probability of an increasing or decreasing sequence of events is equal to the probability as n goes to infinity of an increasing or decreasing sequence of events. I can't see a significant difference that merits the kind of proofs I see in the textbooks. What is the significance of moving the limit inside the brackets? Clearly I'm missing something. Could someone give me some intuition on this please?
There are different ways to answer this.
1. Mathematically, the two sides of the equation represent different operations, so a proof is required to show that they give you the same thing. On the left, you are looking at a limit of probabilities. On the right you are looking at one probability evaluated on a set that is a limit of sets. This equation is not one of the basic assumptions of probability theory; therefore, it demands proof.
2. Why intuitively? Suppose the sequence is decreasing down to the empty set. In that case, the right hand side is the probability of the empty set which is 0. However, the left side represents a limit of probabilities of nonempty events (i.e. positive probabilities). How do you know that there is not some kernel of positive probability that lies inside every nonempty set E_n and that prevents the probability of E_n from converging down to 0. That is more or less what the proof is addressing.
Suppose [itex]\{E_n\}[/itex] is a sequence of events (not necessarily an increasing or decreasing sequence of events). Is the result necessarily true? If not, then something needs to be proven about why the special case of an increasing or decreasing sequences of events implies the result.
  • · Replies 20 ·
9K
