Thread Closed
HELP! Resistors Parallel/series
Share Thread Thread Tools
Mar5-05, 09:00 PM   #1
Red face
Ok the question is:
A resistor (resistance=R) is connected first in parallel and then in series with a 2.00 ohm resistor. A battery delivers five times as much current to the parallel combination as it does the series combination. Determine the two possible values for R.
So let's see: I can use I=V/R
For series it's I=V/(R+2)
For parallel it's 5I=V/(1/R+1/2ohm) Ok, now I equate the Currents (I)
and I get V/(R+2)=V/5(1/R+1/2). I can cancel out the V's and I'll have:
Now I solve for R?
Am I on the right track?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Galaxies fed by funnels of fuel
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> Google eyes emerging markets networks
Mar5-05, 09:48 PM   #2
Your parallel equation is wrong:
[tex]R_{eq}=(\frac{1}{R_1}+\frac{1}{R_2}+\cdots+\frac{1}{R_n})^{-1}[/tex]
So if you say [itex]I=\frac{V}{R_{eq}}[/itex] you end up with:
[tex]I=\frac{V}{(\frac{1}{R_1}+\frac{1}{R_2}+\cdots+\frac{1}{R_n})^{-1}}[/tex]
or more simply:
[tex]I={V}{(\frac{1}{R_1}+\frac{1}{R_2}+\cdots+\frac{1}{R_n})}[/tex]
Your thought process is correct though.
Good luck.
Mar5-05, 09:51 PM   #3
Your equation for equivalent resistnace in a parallel circuit is wrong. The correct equation is:
[tex]\frac{1}{R} = \frac{1}{R_1} + \frac{1}{R_2}[/tex]
Otherwise you seem to be on the right track.
Mar5-05, 10:26 PM   #4
Ok this is weird. Ok so jumping to the equating of the two equation step...
I get :
V/(R+2)=V/5 x (1/R+1/2). Now, I cancel the Vs and try to solve for R
1/(R+2)=1/5 x (1/R+1/2). Now I bring the 5 over on the otherside and now I will solve and get a quadratic equation:
R^2-6R+4=0. Solving for R's I get R=5.236 and R=.7639 ohm.
It looks right? Thanks.
Thread Closed
Thread Tools
Similar Threads for: HELP! Resistors Parallel/series
Thread Forum Replies
series and parallel resistors Introductory Physics Homework 2
resistors in series/parallel Advanced Physics Homework 3
Please help me with resistors in parallel/series - with many variables :) Introductory Physics Homework 1
Resistors in series and parallel Introductory Physics Homework 3
Resistors in series and parallel Introductory Physics Homework 6
