New Reply
three same-mass freight cars, why force on each is not same ?
Share Thread Thread Tools
Dec25-12, 03:16 AM   #1
ato
QUESTION
three cars of mass m are pulled with force F by a locomotive. Find forces on each cars ?
assuming the force F is exerted on car C and nearest to C is car B and remaining one is A.
[tex]\vec{F}_{A}[/tex] is total sum of all (interbody-) forces on car A . similarly [tex]\vec{F}_{B}[/tex] and [tex]\vec{F}_{C}[/tex] are defined.
assuming the forces that the question asks is [tex]\vec{F}_{A}[/tex],[tex]\vec{F}_{B}[/tex] and [tex]\vec{F}_{C}[/tex] and the given information is
$$\vec{F}_{CO}=\vec{F}$$
according to newton's 2nd law
$$\vec{F}_{A}=\frac{d^{2}}{dt^{2}}m\vec{r}_{A}$$,
$$\vec{F}_{B}=\frac{d^{2}}{dt^{2}}m\vec{r}_{B}$$ and
$$\vec{F}_{C}=\frac{d^{2}}{dt^{2}}m\vec{r}_{C}$$
but since
$$\frac{d^{2}}{dt^{2}}\vec{r}_{A}=\frac{d^{2}}{dt^{2}}\vec{r}_{B}=\frac {d^{2}}{dt^{2}}\vec{r}_{C}$$, $$\frac{d}{dt}m =0$$
so above five equations would give
$$\vec{F}_{A}=\vec{F}_{B}=\vec{F}_{C}$$
according to superposition principle,
$$\vec{F}_{A}=\vec{F}_{AB}$$
because there is only one force i.e tension force due to string, exerted on A.
$$\vec{F}_{B}=\vec{F}_{BA}+\vec{F}_{BC}$$
because two tension forces (from both A and C) is acting on B.
$$\vec{F}_{C}=\vec{F}_{CO}+\vec{F}_{CB}$$
because one external force of magnitude F and one tension force from B.
according to 3rd law we also have,
$$\vec{F}_{AB}=-\vec{F}_{BA}$$ and
$$\vec{F}_{BC}=-\vec{F}_{CB}$$.
so from above five equations,
$$\vec{F}_{A}+\vec{F}_{B}+\vec{F}_{C}=\vec{F}_{CO}$$
hence
$$\vec{F}_{A}=\vec{F}_{B}=\vec{F}_{C}=\frac{\vec{F}}{3}$$
but i dont undertand why its wrong because the solution says
$$\vec{F}_{A}=\frac{\vec{F}}{3}$$,
$$\vec{F}_{B}=\frac{2\vec{F}}{3}$$ and
$$\vec{F}_{C}=\vec{F}$$
the only problem think i can think of is may be the question is asking for different forces , because there are forces that have same value for example ,
$$\vec{F}_{BC}=\frac{\vec{2F}}{3}$$,
$$\vec{F}_{C0}=\vec{F}$$
thank you
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> Iron-platinum alloys could be new-generation hard drives
>> Lab sets a new record for creating heralded photons
>> Breakthrough calls time on bootleg booze
Dec25-12, 03:41 AM   #2
Mentor
The question is not asking for the net force on each car, which of course must be equal. It is asking for the force that C exerts on B and B exerts on A in terms of the force F that the locomotive exerts on C.
Dec25-12, 04:01 AM   #3
ato
so the question was indeed asking for $$\vec{F}_{CO}$$,$$\vec{F}_{BC}$$ and $$\vec{F}_A$$ .
i dont understand why not say so in the question, instead of being so short and confusing. i though the book was teaching physics not reading mind.
thanks for the help Doc Al
New Reply
Thread Tools
Similar Threads for: three same-mass freight cars, why force on each is not same ?
Thread Forum Replies
Conservation of momentum continous mass flow freight cart. Introductory Physics Homework 4
freight car-caboose collision finding mass without velocities Introductory Physics Homework 12
Cars and Center of Mass Introductory Physics Homework 1
A freight train has a mass of 4.5*10^7 kg Introductory Physics Homework 2
2 Cars Colliding with same mass Introductory Physics Homework 1
