Register to reply
Angular momentum of rod
Share this thread:
kuyt
#1
Dec26-12, 11:02 AM
P: 8
What is the angular momentum of a rod rotating about one end (mass M and angular velocity ш),about its center of mass?
Phys.Org News Partner Physics news on Phys.org
Mapping the optimal route between two quantum states
Spin-based electronics: New material successfully tested
Verifying the future of quantum computing
Doc Al
#2
Dec26-12, 11:13 AM
Mentor
Doc Al's Avatar
P: 41,323
Quote Quote by kuyt View Post
Is the rod rotating about one end or its center of mass?
kuyt
#3
Dec26-12, 12:08 PM
P: 8
about one end
tadchem
#4
Dec26-12, 01:06 PM
P: 70
A little research is in order.
http://scienceworld.wolfram.com/physics/
http://hyperphysics.phy-astr.gsu.edu/hbase/hframe.html
"There is no need to know all the answers when you know how to find all the answers that have been found before."
kuyt
#5
Dec26-12, 01:13 PM
P: 8
But this is something fundamental,calculating angular momentum of a system about arbitary points in space.
tadchem
#6
Dec26-12, 01:21 PM
P: 70
In the second link the 'bubbles' are hot links.
Navigate through "Mechanics", then "Rotation", then "Moment of Inertia".
Click on "Common Forms" for Enlightenment!
schaefera
#7
Dec26-12, 01:27 PM
P: 208
Find the angular momentum of a differential length (dm*v*r) and integrate from r=0 to L.
HallsofIvy
#8
Dec26-12, 01:30 PM
Math
Emeritus
Sci Advisor
Thanks
PF Gold
P: 39,353
Yes, it is, and you can answer it by calculating the angular momentum of individual point about the end of the rod, then integrating them along the length of the rod. The result of doing that would be the formula at http://scienceworld.wolfram.com/phys...nertiaRod.html
that you could get to following the links you were given in tadchem's response.
kuyt
#9
Dec26-12, 01:43 PM
P: 8
Quote Quote by HallsofIvy View Post
it gives moment of inertia not angular momentum! Can we use the general formula(if its correct):angular moment abt any point=angular moment of a fictitious particle (of mass m at the position of COM)abt that point + angular moment of the body abt com ?
dev70
#10
Dec26-12, 01:52 PM
P: 58
hello kuyt, i think you should have a look at the angular momentum equation ie., L= r X P and v=rw. So, use r=l/2 where l=length of rod. hope that makes sense..
kuyt
#11
Dec26-12, 02:04 PM
P: 8
No,it not that easy I guess.
P.S can anyone giveme the final answer(in terms of angular velocity,mass and length)and ofcourse the explanation,instead of links
schaefera
#12
Dec26-12, 02:06 PM
P: 208
It's (1/3)wmL^2 for angular speed w.
kuyt
#13
Dec26-12, 02:09 PM
P: 8
^but that about one of the ends ,not com
BruceW
#14
Dec26-12, 02:57 PM
HW Helper
BruceW's Avatar
P: 3,443
Ah, so you're trying to find the angular momentum about the com, in a system where the rod is rotating about one end.
kuyt
#15
Dec26-12, 03:02 PM
P: 8
yes
BruceW
#16
Dec26-12, 03:54 PM
HW Helper
BruceW's Avatar
P: 3,443
hmm. Tricky one. Well, I'm pretty sure that the whole point of saying the angular momentum "about a point" is equivalent to calculating the angular momentum, given that the origin is the point about which we want to find the angular momentum.
So I think the angular momentum about the COM is simply angular momentum, given that our origin is the COM. And in our original reference frame, the rod was rotating around the end. So in a reference frame where the COM stays at the origin, the angular momentum will simply be
[tex] \omega \frac{mL^2}{12} [/tex]
(in other words, same as what the angular momentum would be for a system where the rod is rotating around it's COM.)
Astronuc
#17
Dec26-12, 06:02 PM
Admin
Astronuc's Avatar
P: 21,827
The links provide helpful information.
Students are expected to demonstrate effort and show their work. We do not spoon feed students with answers.
Register to reply
Related Discussions
Angular momentum and conservation of angular momentum problem Introductory Physics Homework 0
Angular momentum of rigid bodies,When to add (moment of inertia*angular velociy) Introductory Physics Homework 0
Conserved angular momentum: finding angular velocities of drums as a function of time Introductory Physics Homework 2
Physics Rotating Disk, Moment of Inertia, Angular Momentum, Angular Velocity Introductory Physics Homework 12
Angular momentum and orbital angular momentum problems Introductory Physics Homework 3
