How Does Changing to Polar Coordinates Simplify This Physics Integral?
The discussion revolves around the simplification of a physics integral through the transition to polar coordinates, specifically in the context of a Fourier transform. Participants seek clarification on the steps involved in this transformation and the implications of using three-dimensional integration in k-space.
  • One participant expresses confusion about the transition from a three-dimensional integral to polar coordinates and requests intermediate steps.
  • Another participant questions the meaningfulness of integrating with respect to ##d^3k##, suggesting it should be ##dx## instead.
  • A transcription error is acknowledged, correcting the integral to involve ##\vec{k}^2 + m^2##, which is identified as part of a Fourier transform.
  • Clarification is provided that ##d^3k## denotes a three-dimensional integral, contrasting it with one-dimensional integration.
  • Participants discuss the conversion to spherical coordinates, noting that one factor of ##k## in the numerator arises from the conversion, while another cancels with the denominator.
  • There is a suggestion that the integral can be simplified by assuming that ##\phi(\vec{x})## depends only on the radial coordinate ##r## of ##\vec{x}##.
  • One participant expresses frustration over a lack of clarity in the integration steps, particularly regarding the integration of ##\sin\theta\,e^{ikrcos\theta}##.
  • A later post indicates that a simple substitution resolves some of the confusion regarding the integration process.
Participants express varying levels of understanding regarding the integration process and the notation used. There is no consensus on the clarity of the steps involved, and some participants remain uncertain about specific aspects of the transformation and integration.
Limitations include potential misunderstandings of the notation ##d^3k## and the assumptions made about the dependence of ##\phi(\vec{x})## on the radial coordinate. The discussion also highlights unresolved mathematical steps in the integration process.
VantagePoint72
I'm reading some course notes for a physics class that contain the following step in a derivation:
[itex]\phi(\vec{x}) = \int \frac{d^3k}{(2\pi)^3}\frac{e^{i\vec{k}\cdot\vec{x}}}{\vec{x}^2 + m^2}[/itex]
Changing to polar coordinates, and writing [itex]\vec{k}\cdot\vec{x}=kr \cos\theta[/itex], we have:
[itex]\phi(\vec{x}) = \frac{1}{(2\pi)^2} \int_0^\infty dk \frac{k^2}{k^2 + m^2}\frac{2\sin kr}{kr}[/itex]
I'm having a bit of difficulty seeing this step. Could someone please show some of the intermediate steps between these two and explain what's happening? I understand that k2 in the numerator comes from converting to spherical coordinates, but that's about all I follow.
This seems strange. How can it be meaningful to integrate w.r.t ##d^3k## ?
Oh dear, you're right of course. I made a transcription error, it should be:
[itex]\phi(\vec{x}) = \int \frac{d^3k}{(2\pi)^3}\frac{e^{i\vec{k}\cdot\vec{x} }}{\vec{k}^2 + m^2}[/itex]
It's a Fourier transform. Now that it's fixed, can you see how to proceed?
I still don't understand what ##d^3k## is. Shouldn't it be ##dx## or something like that?
It is a short hand notation to indicate that the integral is 3 dimensional, dx would be 1 dimensional.
Hi LastOneStanding! :smile:
… I understand that k2 in the numerator comes from converting to spherical coordinates …
no, only one k comes from the conversion, the other k cancels with the k in the denominator :wink:
(d3k = ksinθ dkdθdφ, and so you have to ∫ ksinθ eikrcosθ dθ)
Ok, I did never see this notation before. Now, I got it:
First, ##\phi(\vec{x})## depends only upon the radial coordinate ##r## of ##\vec{x}##. (Why?) We can therefore assume that ##\vec{x}## is ##(0,0,r)##. Then ## \theta## is the colatitude of ##\vec{k}## and in spherical coordinates ##d^3 k## becomes ##k^2 \sin \theta \,dk\,d\theta\,d\phi##. Now, it is easy to integrate ##\sin\theta\,e^{ikrcos\theta}## wrt ##\theta##. This will give the desired the result.
I don't follow...the spherical volume element is [itex]d^3x = r^2 \sin\theta dr d\theta d\phi[/itex]. For an integral in k-space, this means a factor of k2. What do you mean "the other k cancels with the k in the denominator"?
As I said in the original question, I understand the part of the step that comes from converting to spherical coordinates. So, unfortunately it is precisely the part of the calculation you suppressed by saying "it is easy to integrate..." which is what I'm stuck on.
Oh, bother. Undone by a simple u-subsitution, sigh. Thank you, Erland, I see how the rest of the integration goes.
