Thread Closed
Gold versus Silver
Share Thread
Jan3-13, 07:03 PM   #1
Gold versus Silver
I am not an engineer so I was wondering if a pound of gold can ever weigh more than a pound of silver under any circumstances relative to the universe as a whole?
John
PhysOrg.com engineering news on PhysOrg.com
>> Mathematical algorithms cut train delays
>> Researchers design software to detect changes in colour vision
>> Trend study identifies potential for humans and technology to interact in a manufacturing environment
Jan3-13, 08:11 PM   #2
Mentor
The question doesn't make sense. A pound is a pound is a pound. They are all equal. But "relative to the universe as a whole" has no meaning I can discern.
Jan4-13, 12:40 AM   #3
Recognitions:
Homework Helper Homework Help
It depends upon which 'pound' unit you are using.
Pounds avoirdupois consist of 7000 grains or approx. 453.6 g
Pounds troy consist of 5760 grains or approx. 373.2 g
1 pound avoirdupois is also divided into 16 ounces, while the troy pound is divided into 12 troy ounces.
When quoting the price of a precious metal like gold, the amount is always for 1 troy ounce.
Jan4-13, 06:15 AM   #4
Gold versus Silver
There is much more stuff. If you are talking a bout the rest mass it will not change as far as we know, but there is also the relativistic mass, and then there is weight (the gravitational force on a planet) So in a way the question is one of language and not of physics.
Jan4-13, 07:34 AM   #5
I was thinking in the terms of Dimensionless Numbers when posting question.
John
Jan4-13, 07:38 AM   #6
Admin
Quote by SteamKing View Post
Quote by 0xDEADBEEF View Post
Let us assume in the context of the OP, that one uses the same unit of mass in the same inertial frame in the same gravitational field. Then a pound is a pound as Russ mentioned. The number of moles (atoms) will be different and volumes will be different.
Silver has an atomic weight (mass) of 107.87 amu and density of 10490 kg/m3, and gold has an atomic mass of 196.97 amu and density of 19300 kg/m3. The density is reported at room temperature and 1 atm pressure.
Jan4-13, 08:05 AM   #7
John
The short answer is no since the measure 1 pound mass is almost independent of the material considered and quite independent for practical purposes.
However
The weight of a 1 pound mass is a measure of the force of attraction of gravity, which in turn is the aggregated sum of the forces of attraction of all the particles.
Now it is entirely conceivable that one pound mass of rarified gas in a tall thin column might aggregate to less attractive force than a flat, consolidated lump of gold because the upper particles are further away and therefore subject to a smaller force of attraction in the gas column.
However you have specified gold and silver which will make very similar lumps.
The other issue is whether you can fit an exact number of atoms of either into one pound mass.
So if you wish to measure the quantity of gold or silver by whole numbers of atoms then yes the gold will weigh more.
Further both metals have isotopes that would change these weights slightly if included.
Jan4-13, 10:28 AM   #8
Recognitions:
Which weighs more? A pound of lead or a pound of feathers?
Jan4-13, 11:30 AM   #9
D H
Mentor
You are off topic because gold and silver are both precious metals. Stop. Now.
Quote by John1397 View Post
Yes. A pound of gold at the center of the Earth weighs nothing, more or less. An avoirdupois pound of silver at the mantle-core boundary weighs more than a pound (pound force).
This makes no sense, so I ignored this part of your question.
Jan4-13, 02:09 PM   #10
Quote by D H View Post
Just speculating that on other planets weights of elements could be different.
Jan4-13, 02:20 PM   #11
D H
Mentor
No.
Read our rules on posting "personal theories or speculations that go beyond or counter to generally-accepted science."
Thread locked.
Thread Closed
Similar discussions for: Gold versus Silver
Thread Forum Replies
Fission to make gold or silver High Energy, Nuclear, Particle Physics 13
Why the surface plasmon always use gold or silver as a metal film? Atomic, Solid State, Comp. Physics 3
Gold and Silver Introductory Physics Homework 2
Can you gold plate a penny using gold nitrate? Chemistry 8
"Generation" of gold, silver, copper elements General Physics 1
