New Reply
Induction with waveguide walls
Share Thread Thread Tools
Jan4-13, 12:28 PM   #1
This is a question I've been trying to figure out. I'll try my best to formulate it, so apologies if it's a bit ill defined!
Suppose you construct a finite parallel plate waveguide of PEC(perfect electrical conductors) and PMC(perfect magnetic conductors) so that the top/bottom plates are PEC, and the left/right are PMC. For instance, something like this but instead of air on the sides, it's a PMC so H = 0.
1) Then what happens if you propagate a TE wave? More specifically, will there be any sort of induction with the walls?
2) If not, could you construct some internal structure in the waveguide which couples to the walls of it?
This is what I have for 1) so far:
There can't be any induction with the PMC walls, because along the surface of the PMC, the magnetic field is 0 in all directions.
We have then have BC's that:
[itex]\vec{E}(x=0) = \vec{E}(x=d) = \vec{0}[/itex]
And then from maxwell's equations, the induced surface current is:
[itex]J_s = \pm \hat{x} \times \vec{H} = \pm (\hat{y} H_z - \hat{z} H_y)[/itex]
I'm a bit rusty on how to calculate any sort of behaviors here via induction onwards.
I'm guessing that since this is TE, H only has y and z components. Therefore, there is no induced electric field since the magnetic flux from one plate to another is 0. That would therefore imply, to produce inductive effects with some internal structure (2), we could construct a wire loop slanted at 45°
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> New analysis yields improvements in a classic 3D imaging technique
>> Research effort deep underground could sort out cosmic-scale mysteries
New Reply
Thread Tools
Similar Threads for: Induction with waveguide walls
Thread Forum Replies
Waveguide-waveguide coupling or directional coupler Classical Physics 0
waveguide Introductory Physics Homework 19
Waveguide Help Engineering, Comp Sci, & Technology Homework 4
Waveguide Advanced Physics Homework 10
seeing through walls Introductory Physics Homework 7
