| New Reply |
Heat Transfer Coefficients and Nusselt Numbers of Various Materials |
Share Thread | Thread Tools |
| Jan4-13, 05:05 PM | #1 |
Hi everybody!
I am working in a solid state physics group and need to find some heat transfer data to finish my calculations. I need to find the Nusselt number Nu[itex]=\frac{hL}{K}[/itex] describing the heat transfer interface between a Si wafer and helium gas at a variety of temperatures. To find this I need the heat transfer coefficient [itex]\left(h\right)[/itex] between Si and He. I will most likely be needing this sort of data for other materials in the future so I was wondering if someone could direct me to some sort of table for this type of data? Thank you for your help! |
| PhysOrg.com |
physics news on PhysOrg.com >> Iron-platinum alloys could be new-generation hard drives >> Promising doped zirconia >> Nanocrystals grow from liquid interface |
| Jan4-13, 07:05 PM | #2 |
Welcome to physics forums. The heat transfer coefficient and Nussult Number are not properties of the materials. The Nussult Number is basically the dimensionless version of the heat transfer coefficient. The heat transfer coefficient is determined by heat conduction and convective heat transport in the gas in close proximity to the interface. The helium will be moving, shearing, and deforming, and its molecules will conduct heat to and from the interface. The shearing and deformation of the gas has the effect of changing the temperature gradient, which affects the rate of heat conduction. If you want to learn more about the heat transfer coefficient and the Nussult number, see Transport Phenomena by Bird, Stewart, and Lightfoot. For your situation, the heat transfer between the helium and the substrate will be dominated by the thermal resistance on the gas side of the interface. Therefore, you need to study the heat transfer behavior in the gas phase, which will be determined by the geometry and the fluid mechanics in the gas. To a large extent, the substrate will not matter. Chet |
| Jan5-13, 03:57 PM | #3 |
Hey Chet,
Thanks for the reference! I will definitely check it out. If you don't mind asking me another question, is the equation wikipedia uses to describe the relationship: [itex]h=\frac{Q}{AT}[/itex] an oversimplification in this sort of situation? It makes sense that the heat transfer process is dominated by the thermal resistance of the gas, but I'm wondering what kind of role the fluid flow plays in this process. Thanks for the reply. |
| Jan5-13, 05:12 PM | #4 |
The heat transfer coefficient is used to calculate the heat flow Q by the equation Q = hAΔT. But, to use this equation, you need to be able to either estimate the heat transfer coefficient from experience or solve the detailed partial differential equations for heat transport and fluid flow for the heat transfer coefficient. As I said in my previous response, the gas flow can have a substantial effect on the gas phase temperature gradient near the interface, and this is equivalent to an effect on the heat transfer coefficient. On a calm day outside, your skin temperature is much higher than when the wind is blowing. The wind movement increases the heat transfer coefficient between your skin surface and the bulk temperature of the air. Right near your skin, there is a thin thermal boundary layer, on the order of about a mm thick, over which the air temperature varies from the "free stream" air temperature to your skin temperature. The heat transfer coefficient is inversely proportional to the thickness of this boundary layer. When the wind is blowing, the thermal boundary layer becomes thinner, and the heat transfer coefficient increases.
| New Reply |
| Tags |
| solid state physics, thermal conduction |
| Thread Tools | |
Similar Threads for: Heat Transfer Coefficients and Nusselt Numbers of Various Materials
| Heat Transfer: Calculating heat transfer rate? | Engineering, Comp Sci, & Technology Homework | 4 | ||
| convection heat transfer coefficients ? | Classical Physics | 2 | ||
| Convective heat transfer coefficients | Classical Physics | 0 | ||
| Problem on the transfer of heat into different materials | Introductory Physics Homework | 2 | ||
| Rayleigh and Nusselt numbers | General Physics | 3 | ||
