Why is the total force on an object treated as acting on its center of mass?
The discussion revolves around the treatment of total force acting on an object as if it were applied at the center of mass, particularly in the context of rotational mechanics and torque calculations. Participants explore the implications of this treatment for rigid bodies and the conditions under which it holds true.
  • Some participants propose that the total force can be considered as acting at the center of mass due to symmetry and the nature of rigid body motion.
  • Others argue that the total force cannot simply be treated as acting at the center of mass without considering its components and the distribution of forces.
  • A participant discusses Euler's rotation theorem and its implications for the momentum and angular momentum of rigid bodies, suggesting that the total momentum is related to the center of mass velocity.
  • Another participant questions whether the assumption of equal and opposite forces is necessary for deriving the equations related to angular momentum.
  • Some participants clarify that the torque due to gravity is zero around the center of mass under uniform gravitational fields, while noting that variations in the gravitational field could introduce torque.
  • There is a discussion about a specific scenario involving a pencil nailed to a wall, where participants analyze the legality of applying total force at the center of mass to calculate torque.
Participants express differing views on whether the total force can be treated as acting at the center of mass without additional considerations. The discussion remains unresolved regarding the necessity of certain assumptions, such as the nature of forces and the conditions under which the equations apply.
Limitations include assumptions about rigid body motion, uniform mass distribution, and the effects of gravitational fields. The discussion does not resolve the implications of these assumptions on the validity of the arguments presented.
Swimmingly!
Why can the total force exerted on an object be taken as if a single force was applied on the center of mass?
I think at most the total force must be the sum of tiny equal forces uniformly distributed. The mass must at most be uniformly distributed too.
And this only matters when we start talking about rotational mechanics, right? i.e: Torques. So that the torque can be calculated as [itex]\tau[/itex]=[itex]R \times{F}_{T}[/itex]. But why is this true?
R being the vector of the position of the COM.
I think it can be explained this way:Using the known equation:
[itex]\boldsymbol{L}=\boldsymbol{L}_{CM}+\boldsymbol{L}_{spin}[/itex]
[itex]{L}_{CM}=[/itex] is the L of a point particle in the COM with mass M.
[itex]{L}_{spin}[/itex] is the L of body relative to it's center of mass.
Now by symmetry. Since [itex]{L}_{spin}[/itex] is on the center of mass it must be 0. There's an equal amount of tiny forces on each side of the body which makes the torque 0.
Can anyone just give me some insight into this? I just want to understand this basic clearly and there may be a simpler broader explanation.
Why can the total force exerted on an object be taken as if a single force was applied on the center of mass?[/quote]In general, it can't. You express the applied force in components through the com and perpendicular to that.
luckily, I have just been going over rotational dynamics, so here's what I got! Firstly, I should say this is all for the motion of a rigid body. These equations won't work if the object is not rigid. First up, for any two points which are both fixed with respect to the rigid body:
[tex]\frac{d( \vec{r}'- \vec{r})}{dt}= \vec{\omega} \wedge (\vec{r}'-\vec{r})[/tex]
Which I think is just another way of saying Euler's rotation theorem. Now, from this, if we calculate the total momentum of a rigid body we get:
[tex]\vec{P}=M \frac{d \vec{r}}{dt} + M \ \vec{\omega} \wedge (\vec{R} - \vec{r})[/tex]
Where [itex]\vec{P}[/itex] is the total momentum of the rigid body, [itex]M[/itex] is the total mass of the rigid body, [itex]\vec{R}[/itex] is the centre of mass of the rigid body and [itex]\vec{r}[/itex] is any arbitrary point which is fixed with respect to the rigid body. Finally, [itex]\vec{\omega}[/itex] represents the instantaneous rotation of the rigid body.
So, now if we choose [itex]\vec{r}=\vec{R}[/itex] (which is always allowed, since the centre of mass is always a fixed point with respect to the rigid body), then the equation simplifies very nicely:
[tex]\vec{P}=M \frac{d \vec{R}}{dt}[/tex]
So we see the total momentum of a rigid object is due to the velocity of its centre of mass, times by the total mass of the object. Now, using a similar, but longer calculation, to get the total angular momentum of the rigid body, gives the equation:
[tex]\vec{L}= \vec{R} \wedge \vec{P} + \underline{I_{(\vec{r})}} \cdot \vec{\omega} - M(\vec{r} - \vec{R}) \wedge \frac{d(\vec{r} - \vec{R})}{dt}[/tex]
Where [itex]\underline{I_{(\vec{r})}}[/itex] is the inertia matrix, calculated around the point [itex]\vec{r}[/itex] (which, again, is any point which is fixed with respect to the rigid body). So from the above equation, you can see that the total angular momentum is due to the angular momentum of the centre of mass with respect to the origin (the first term), and the second term is due to the angular momentum of the rigid body around some point which is fixed with respect to the rigid body, and the third term has no easy interpretation, but it is sort of like the negative of the angular momentum of the fixed point with respect to the centre of mass.
Now, remember the fixed point can be any point which is fixed with respect to the rigid body. so if you are given the the inertia matrix around some point which is not the centre of mass, then you can use the above formula. But if you are given the inertia matrix around the centre of mass, then you are very lucky, because the third term disappears, and we get:
[tex]\vec{L}= \vec{R} \wedge \vec{P} + \underline{I_{(\vec{R})}} \cdot \vec{\omega}[/tex]
Which is nicer. (and this is why the inertia matrix around the centre of mass is most often used).
So is this nice property of the angular momentum around the centre of mass due to lots of equal and opposite forces? Not necessarily. You don't have to assume that to get these equations. (Although it is probably a sufficient condition).
To get these equations, the only thing you really need to do is assume that it is a rigid body, and then the rest will follow.
Edit: I'm not even that sure that equal and opposite forces are a sufficient condition... Obviously, they don't imply a rigid body, so I don't think equal and opposite forces are a useful assumption.
Sorry if my exposition wasn't so good.
I had done this when I posted but I was doubtful about something, it seems fine though.
I just have to take the derivative applying the product rule:
[itex]\boldsymbol{\tau}=\boldsymbol{\tau}_{CM}+ \boldsymbol{\tau}_{spin}[/itex], but [itex]\boldsymbol{\tau}_{spin} = 0[/itex] *
[itex]\boldsymbol{\tau}=\boldsymbol{\tau}_{CM}[/itex]
QED
*If a is constant: [itex]\boldsymbol {\tau}_{spin} = \sum {r_{i} \times m_{i}a} =( \sum {m_{i}r_{i}}) \times a=0 \times a=0[/itex]
Bruce, I think you demonstrated the first equation correct? I accepted that but I was suspicious of it's direct result through derivation, I can't remember why but oh well.
If I misunderstood something I'm sorry. I didn't know about Euler's rotational theorem. Thanks!
Edit, clear up: The question was basically this.
If a pencil is nailed to wall. If there's no friction and the pencil's horizontal what's the torque on the pencil? We just take the total force, put it on the center of mass of the pencil and torque=r*F, with r=length/2. Why is this legal?
It's now answered I think.
Yep, that's it. The torque around the centre of mass due to gravity is zero. In your equation, 'a' should really be [itex]\vec{g}[/itex], since there may be other forces which can cause torque around the centre of mass, so 'a' can generally be something else, but the important thing is that the force due to gravity causes zero torque around the centre of mass.
Also, it's important to remember that this is only true when the gravitational field is uniform. (That is why you were able to say that the acceleration due to gravity is the same on each small element of the rigid body). So if the gravitational field varied throughout space, then generally it would cause a torque around the centre of mass.
it is simple.Just put two equal and opposite forces on center of mass,now this does not change anything.You can see that one force of it and the force at other end will form a couple which is equal to torque also the residing force at center of mass will be in the same direction as the applied force on one end.So you can think that force at one end could be transferred to COM and then an additional torque is needed.
Let's make it easier - so we don't have to worry about the reaction at the wall ... as much.
mount the pencil on a pivot at the wall and hold it horizontal then let go.
At the instant you let go - the total torque is taken as MgL/2 where M is the total mass of the pencil and L it's overall length.
This assumes a uniform mass-distribution for the pencil - so it is very blunt and has no eraser on the other end ;)
This is "legal" because it agrees with the results of experiments... i.e. the Universe works like this. Physics is an empirical science, so this is the bottom line.
We can see that it is mathematically consistent with the rest of our physical models by considering how the total torque is made up ... gravity, after all, acts on the entire length of the pencil. Thus, you can work out the torque about the pivot due to gravity acting on each bit of the pencil and add them up (provided you are comfortable with torques adding up?)
I doubt it will be very convincing if I do the math here - so you will have to.
Hows your calculus?
Try for differently shaped objects.
Try it for an arbitrarily shaped mass distribution.
Then you will see.
Since this is the same result all the time, there is no need to repeat the whole calculation every single time we have to do one of these problems.
  • · Replies 38 ·
15K
  • · Replies 51 ·
  • · Replies 52 ·
  • · Replies 77 ·
