| New Reply |
conductivity of metals at 0 kelvin? |
Share Thread | Thread Tools |
| Jan14-13, 04:47 AM | #18 |
classical calculation does not apply as I already said.It is pointed out in feynman lectures vol. 1 that uncertainty principle must be invoked for non zero entropy.see some early chapter,it is written there.
| Jan14-13, 05:54 AM | #19 |
Mentor
Zz. |
| Jan15-13, 05:14 AM | #20 |
| Jan15-13, 04:05 PM | #21 |
Mentor
I don't see any classical calculation in my post.
| Jan16-13, 07:05 AM | #22 |
does your eqn take into account the uncertainty principle.I don't think so.
| Jan16-13, 09:04 AM | #23 |
Mentor
The pi take the uncertainty principle into account.
Seriously, I don't understand your problem with my equation. You just repeat "uncertainty principle" every time. It is like I would counter this with "particle mass" all the time. I mean, where is your point? |
| Jan16-13, 10:05 AM | #24 |
Mentor
The problem here is that people think that the HUP is a starting point in QM rather than merely a consequence. It is as if one has to forcibly introduce the HUP into something, rather than realizing that it is naturally built in when one adopts the QM formalism.
Zz. |
| Jan17-13, 12:55 AM | #25 |
Also the formula written by you is classical one,it is called Gibbs entropy S=-kBƩpi lnpi quoting wiki For a classical system (i.e., a collection of classical particles) with a discrete set of microstates, if Ei is the energy of microstate i, and pi is its probability that it occurs during the system's fluctuations, then the entropy of the system is S=-kBƩpi lnpi |
| Jan17-13, 01:52 AM | #26 |
Recognitions:
Quantum mechanically, the statistical entropy is defined by von Neumann's formula
##S=-k\mathrm{Tr}\rho \ln \rho ## where ##\rho## is the so called density matrix. This expression can be evaluated in a basis which diagonalizes the density matrix. The density matrix only has non-negative eigenvalues $p_i$ which can be interpreted as occupation probabilities. Hence von Neumann's expression reduces to Gibbs expression. Especially for a pure quantum mechanical state, only one of the p_i is 1, the others being 0. Hence the entropy vanishes for a pure state. Already for a single particle there are pure states with non-vanishing velocity or current. Hence finite current and vanishing entropy are not contradictory, even when QM effects are taken into account. |
| Jan17-13, 06:43 AM | #27 |
| Jan17-13, 06:58 AM | #28 |
| Jan17-13, 07:18 AM | #29 |
in terms of a density matrix this expression is fine and yields the required classical form.It will also yield zero for entropy if pure state is used.But it seems like to build up on classical analogy.It seems to be a matter of definition.One can go with it.But then usual definition of entropy must not apply(randomness) |
| Jan17-13, 07:55 AM | #30 |
Mentor
It can be different from zero (with a degenerate ground-state), but it does not have to. The dependencies look like that: [Basics of QM] -> uncertainty principle [Basics of QM] -> zero entropy at zero temperature (possible) Therefore, it is meaningless to ask how you can "derive", or "include" the uncertainty principle in (QM) statistical mechanics. It is impossible to avoid it! |
| Jan17-13, 08:30 AM | #31 |
Recognitions:
| Jan17-13, 09:13 AM | #32 |
Mentor
That is true. I just keep track of that special case as it is not forbidden.
| Jan18-13, 01:06 AM | #33 |
| Jan18-13, 03:55 AM | #34 |
| New Reply |
| Thread Tools | |
Similar Threads for: conductivity of metals at 0 kelvin?
| What affects the resistivity/conductivity of metals? | Introductory Physics Homework | 6 | ||
| electrical conductivity metals chart | Electrical Engineering | 2 | ||
| Thermal conductivity of metals | General Physics | 3 | ||
| [SOLVED] conductivity of metals | Advanced Physics Homework | 13 | ||
| Thermal conductivity of metals | Introductory Physics Homework | 5 | ||
