Register to reply
A Gear Ratio Torque Problem
by TheAustrian
Tags: gear, ratio, torque
Share this thread:
TheAustrian
#1
Jan10-13, 08:24 PM
P: 165
Hi all... I'm new here...
this is not a homework question, I'm just solving practice questions for exam preparation
Two wheels with masses M1 = 2 kg and M2 = 4 kg are connected.
The ratio is R1 = 5 cm and R2 = 10 cm
Considering an angular velocity of ωo = 10rads-1
for the small wheel and a constant angular acceleration of α = 1
rads-2
What will be the torque τ required to stop the system after 20 s within a
period of 2 s?
2. Relevant equations
T1ω2=T2ω1
and
P = E/t
3. The attempt at a solution
I already found the energies of the Gears,
E1= 1.125J and E2=2.25J
but I have no idea how to find the torque needed to stop them in 2 seconds. I'm not even sure if I'm on the right track. I have like 3-4 A4 sheets worth of work all scribbled on/crossed out...
actually my problem is that if I work out the Torques, their ratio comes out at 0.25 rather than 0.5, so I'm not sure what to do.
Phys.Org News Partner Science news on Phys.org
Experts defend operational earthquake forecasting, counter critiques
EU urged to convert TV frequencies to mobile broadband
Sierra Nevada freshwater runoff could drop 26 percent by 2100
voko
#2
Jan10-13, 11:50 PM
Thanks
P: 5,801
I think you could use the simple relationship between torque and angular momentum. Energy makes this more complicated than it needs to be.
TheAustrian
#3
Jan10-13, 11:56 PM
P: 165
Quote Quote by voko View Post
But how will that allow me to calculate the question?
voko
#4
Jan11-13, 12:25 AM
Thanks
P: 5,801
In 20 seconds the system will have a certain amount of angular momentum. You need to apply some constant torque to bring it down to zero in 2 seconds.
TheAustrian
#5
Jan11-13, 12:36 AM
P: 165
So I should work out time taken to get angular momentum to zero and work on from there?
voko
#6
Jan11-13, 12:37 AM
Thanks
P: 5,801
You are GIVEN this time: 2 seconds.
TheAustrian
#7
Jan11-13, 01:00 AM
P: 165
Sorry, I phrased myself wrongly here
I meant I should work out the Angular momentum to get to zero in the time-span of two seconds, and then I need to work from there? Is there a relationship that connects torque and angular momentum?
voko
#8
Jan11-13, 01:02 AM
Thanks
P: 5,801
Torque is the rate of change of angular momentum.
TheAustrian
#9
Jan11-13, 01:19 AM
P: 165
With respect to time?
voko
#10
Jan11-13, 01:40 AM
Thanks
P: 5,801
Yes, with respect to time. Since you are preparing for an exam, I suggest that you review the fundamentals of rotary motion. The relationship between angular momentum and torque is the equivalent of Newton's law, and you must know it even if awaken in the middle of the night!
TheAustrian
#11
Jan11-13, 03:37 PM
P: 165
I think I will just surrender, I do not see how Angular Momentum should come into the question, if it's Torque I must know...
Thanks for trying to help though.
voko
#12
Jan12-13, 12:44 AM
Thanks
P: 5,801
This is a pity.
The equation you should remember is ## \displaystyle \tau = \frac {d L } {d t } ##, where ## \tau ## is torque, and ## L ## is angular momentum. This is analogous to Newton's second law: ## \displaystyle F = \frac {d p} {d t} ##. Assuming the torque is constant, as the problem requires, this simplifies to ## \displaystyle \tau = \frac {\Delta L} {\Delta T} ##, where ## \Delta L ## is the change of angular momentum and ## \Delta T## is the period of time during which the change occurs.
## L = I \omega ##, where ## I ## is the moment of inertia and ## \omega ## is angular velocity. Knowing the moments of inertia of the two wheels and their angular velocity, you know the net angular momentum, and the rest is simple.
Register to reply
Related Discussions
Simple Gear Ratio Problem Introductory Physics Homework 3
Torque/hp philosophy (infinant gear ratio) Automotive Engineering 7
Torque and gear ratio help please? Mechanical Engineering 2
Net torque Problem in gear system Classical Physics 13
Help with gear ratio General Engineering 1
