Calculating Coefficients for Dirichlet Series Expansion of a Function
  • Context: Graduate
  • Thread starter Thread starter eljose
    Series
The coefficients a(n) for the Dirichlet series expansion of a function f(s) are calculated using the formula a(n) = (1/ log n) ∫₁^{∞} (f(s)/s) (ds/n^s). This formula can also be represented as a(n) = (1/ log n) ∫₀^{∞} f(s) e^{-s log n} (ds/s). It is derived from the Mellin transform and the Euler-Maclaurin summation formula, and is applicable only to functions with a finite number of poles in the complex plane. Numerical integration techniques can be employed to evaluate the integral in the formula.
  • Understanding of Dirichlet series
  • Familiarity with the Mellin transform
  • Knowledge of the Euler-Maclaurin summation formula
  • Proficiency in numerical integration techniques
  • Study the properties of Dirichlet series and their convergence
  • Learn about the Mellin transform and its applications
  • Explore the Euler-Maclaurin summation formula in detail
  • Investigate numerical integration methods for evaluating integrals
Mathematicians, researchers in analytic number theory, and anyone involved in the study of series expansions and complex functions will benefit from this discussion.
eljose
Dirichlet series...
let,s suppose we wantto expand a function f(s) into a dirichlet series of the form:
[tex]f(s)=\sum_1^{\infty}\frac{a(n)}{n^s}[/tex]
then what would be the formula to get the coefficients a(n)?..thanks...
deja vu
I don't think I have much more to add right now, except bravo on your use of LaTeX.
The formula for calculating the coefficients a(n) for a Dirichlet series expansion of a function f(s) is given by:
a(n) = \frac{1}{\log n} \int_1^{\infty} \frac{f(s)}{s} \frac{ds}{n^s}
This formula can also be written as:
a(n) = \frac{1}{\log n} \int_0^{\infty} f(s) e^{-s \log n} \frac{ds}{s}
This formula is derived using the Mellin transform and the Euler-Maclaurin summation formula. It allows us to express the coefficients a(n) in terms of the function f(s) and the logarithm of n. The integral in the formula can be evaluated numerically using numerical integration techniques.
It should be noted that this formula is only valid for functions that have a Dirichlet series expansion, which means they have a finite number of poles in the complex plane. If the function has an infinite number of poles, then the Dirichlet series expansion does not exist and this formula cannot be used.
In summary, to calculate the coefficients a(n) for a Dirichlet series expansion of a function f(s), we use the formula:
a(n) = \frac{1}{\log n} \int_1^{\infty} \frac{f(s)}{s} \frac{ds}{n^s}.
This formula allows us to express the coefficients in terms of the function f(s) and the logarithm of n, and can be evaluated numerically using integration techniques. However, it is only valid for functions that have a Dirichlet series expansion.
