| Thread Closed |
prime pairs |
Share Thread | Thread Tools |
| May29-05, 09:02 PM | #86 |
prime pairs
Reality does not exclude the possibility that there are infinite primes, reality only deems that we can never know ALL of them. In that sense, yes, we will only see a finite number of primes, but you must accept that there is always another one, and another one, and another vigintillion greater than them.
| May29-05, 09:03 PM | #87 |
| May29-05, 09:11 PM | #88 |
For prime number 7 there is a pattern of 4 + 3. At the square, take FOUR lines down, swap to fifth position, and you'll find 77, Move THREE lines down, swap to first place, you'll find 91. Eleven has a pattern of 3 + 8, and I already know what pattern 13 has because the last number of 11 (8) is repeated in first place for the pattern of 13 (8 + 5). The total is also 13, so I now know also 17's pattern (5 + 12), etcetera. The pattern is based on divying up the natural numbers in lines of six. |
| May29-05, 09:26 PM | #89 |
| May30-05, 03:28 AM | #90 |
Recognitions:
"creates a pattern"?
what pattern does it create according to what rules, and what does the existence of this pattern imply? That there are a finite number of primes? Please, stop posting such nonsense, for the love of mathematics. |
| May30-05, 04:07 AM | #91 |
Take this:http://homepage.ntlworld.com/paul.va...ME%20GRIDS.htm I discovered that the 'Ero-sieve' is not anatural representation of the numbers used, if one diagonalize's the cells into a certain progressive angle, then certain patterns arise. I did not know at the time that this pattern is actually pertaining to:http://eureka.ya.com/angelgalicia30/Primesbehaviour.htm which is quite an amazing site! One can see that Prime numbers behave in a specific way?..if one uses the 'rectangle Sieve' for the first one hundered primes, there is NO concerning pattern that emerges. But if one Diagonalize's the sieve boxes, then one see's the Pattern is Emergent! What is the significance?..it happens to be connected to Fractals and Prime Number distribution of real numbers, and my lack of Mathematical skills gave me a false sense of achievement ..the process was allready in existence, with maybe a slight of hand!
| May30-05, 07:03 AM | #92 |
Recognitions:
Same thing. In a basic Eratosthenes of size N you'll store your information in a string of N bits, where the nth bit is 1 if n is prime, 0 if it's composite. You start with a string of all 1's, 111111.... First stage you remove 1: 011111... Next stage multiples of 2:0110101010... then multiples of 3:01101010001.. And so on. Presieving by 2 and 3 is not only to save time but space. We need only consider numbers congruent to 1 or 5 mod 6, so this is the sequence we store. We need only about N/3 bits, the first bit represents 1, the next 5, the next 7, the next 11, then 13, and so on. Each pair of bits is one of your rows, so I'm going to seperate them with commas. First stage we knock off 1: 01,11,11,11,11,11,... Next stage we knock off multiples of 5, this isn't as straightforward due to how our string is indexed, but we can easily see that we need to jump ahead 4 pairs and remove the first in the pair (this is 25) then we jump ahead one pair and remove the second (35) to get: 01,11,11,11,01,10,...And we continue jumping 4 pairs, 1 pair, 4 pairs, 1 pair crossing off as we go. Replace pair with line and this is what you're describing. I described in an earlier post how you'll know how many pairs (used your line terminology) to jump based on the k and the 1 or 5 in your primes representation as p=6k+1 or p=6k+5. Here k is just indexing the pair (or line) you're in (starting at 0) and 1 or 5 is whether you are 1st or 2nd in the pair. A nice thing about Euclid's proof is that it's somewhat constructive and you can phrase in such a way to avoid the troublesome "infinite". If you take *any* finite list of primes then it not only guarantees there is a prime not on your list but also gives a multiple of this new prime, so you could find it with a little factoring. If you start with 3 and 5 it gives N=3*5+1=16, which though not prime has a the prime divisor 2, not on our list. We now take 2,3,5 and make N=2*3*5+1=31, another prime not on our list. So, when you've gotten to the point where you think you have all the primes, find the corresponding N and then what? What in your "reality" goes wrong? Did you just find a number with no prime factors? (do you think that's possible?) |
| May30-05, 11:20 AM | #93 |
I do not try to undermine math, math is fine as it is. I was just answering a question, and bumped into the limitations. You may think the limitations are inside of me (and you may be right), I think the limitation exist in math (in that it is abstract only, despite its many realistic applications). The thread divulged into a question about the infinite, which does not belong in this thread. My famous last words: I think the infinite in math is a mirror's mirror's image that is being given value. The infinite image truly exists — we need not argue about that — but is it still reflective of reality? Thanks again. |
| May30-05, 01:36 PM | #94 |
| Thread Closed |
| Thread Tools | |
Similar Threads for: prime pairs
| a prime number which equals prime numbers | General Math | 10 | ||
| Photon Pairs - Can photons travel in pairs? | Quantum Physics | 7 | ||
| A formula of prime numbers for interval (q; (q+1)^2), where q is prime number. | Linear & Abstract Algebra | 0 | ||
| Prime Numbers in the Diophantine equation q=(n^2+1)/p and p is Prime | Linear & Abstract Algebra | 5 | ||
| Prime double pairs. | Linear & Abstract Algebra | 3 | ||
