Poisson Bracket for 1 space dimension field
The discussion centers on deriving the equal time Poisson Bracket for a collection of fields \(\phi^i(t,x)\) in one spatial dimension, governed by a specific Lagrangian. The momenta conjugate to the fields are defined as \(\pi_i = A_i + b_{ij} \phi'^{j}\), where \(A_i = g_{ij} \dot{\phi}^{j}\). The correct expression for the Poisson Bracket \(\{A_i(t,x),A_j(t,y)\}\) is established as \((\partial_i b_{jk} + \partial_j b_{ki} + \partial_k b_{ij}) \phi'^{k} \delta(x-y)\). The solution involves using the identity \(f(x) \delta'(x-y) = f(y) \delta'(x-y) - f'(x) \delta(x-y)\) to eliminate derivatives of Dirac deltas and obtain the desired terms.
  • Understanding of Lagrangian mechanics and field theory.
  • Familiarity with Poisson Brackets and their properties.
  • Knowledge of tensor calculus, specifically symmetric and antisymmetric tensors.
  • Experience with Dirac delta functions and their derivatives.
  • Study the derivation of Poisson Brackets in classical field theory.
  • Explore the properties of symmetric and antisymmetric tensors in physics.
  • Learn about the application of Dirac delta functions in mathematical physics.
  • Investigate advanced topics in Lagrangian mechanics, particularly in field dynamics.
Researchers and students in theoretical physics, particularly those focusing on classical field theory, Lagrangian dynamics, and mathematical formulations involving Poisson Brackets.
Bobdemaths
Hi,
Suppose you have a collection of fields [itex]\phi^i (t,x)[/itex] depending on time and on 1 space variable, for [itex]i=1,...,N[/itex]. Its dynamics is defined by the Lagrangian
[itex]L=\frac{1}{2} g_{ij}(\phi) (\dot{\phi}^i \dot{\phi}^j - \phi ' ^i \phi ' ^j ) + b_{ij}(\phi) \dot{\phi}^i \phi ' ^j[/itex]
where [itex]\dot{\phi}^i[/itex] denotes the time derivative of the field [itex]{\phi}^i[/itex] and [itex]\phi ' ^i[/itex] denotes its space derivative, and where [itex]g_{ij}(\phi)[/itex] is a symmetric tensor, and [itex]b_{ij}(\phi)[/itex] an antisymmetric tensor.
One easily computes that the momenta conjugate to the fields [itex]\phi^i (t,x)[/itex] are [itex]\pi_i = A_i + b_{ij} \phi ' ^j[/itex], where [itex]A_i = g_{ij} \dot{\phi}^j[/itex].
Now I would like to show that the (equal time) Poisson Bracket [itex]\{A_i,A_j\}[/itex] is
[itex]\{A_i(t,x),A_j(t,y)\}=(\partial_i b_{jk} + \partial_j b_{ki} + \partial_k b_{ij} ) \phi ' ^k \delta(x-y)[/itex]
using the canonical relation [itex]\{\phi ^i(t,x) , \pi_j (t,y)\}=\delta_j^i \delta(x-y)[/itex].
I tried to write [itex]A_i = \pi_i - b_{ij} \phi ' ^j[/itex], and then use [itex]\{\phi ' ^i(t,x) , \pi_j (t,y)\}=\delta_j^i \delta ' (x-y)[/itex]. But then I can't get rid of the [itex]\delta '[/itex], and I don't get the [itex]\partial_k b_{ij}[/itex] term.
Am I mistaken somewhere ? Thank you in advance !
OK I found the answer. To get rid of the derivatives of Dirac deltas, I used the identity [itex]f(x) \delta ' (x-y) = f(y) \delta ' (x-y) - f'(x) \delta (x-y)[/itex] which follows from the convolution between delta and [itex](f \times \varphi)'[/itex] ([itex]\varphi[/itex] is a test function).
This also produces the remaining wanted term.
  • · Replies 17 ·
  • · Replies 0 ·
  • · Replies 30 ·
