The discussion revolves around the interpretation of older notation used in nuclear physics to describe reactions, specifically the notation p(p,n)Δ^{++}. Participants explore the implications of this notation regarding projectiles and targets, as well as its relevance in contemporary research.
- Exploratory
- Debate/contested
- Technical explanation
- The original poster questions the meaning of the notation p(p,n)Δ^{++} and its implications for identifying projectiles and targets.
- Some participants suggest that the notation does indicate something about the projectile and target, but there is uncertainty about which is which.
- One participant expresses skepticism about the relevance of older sources in modern research, while others defend the value of older literature.
- There is a comparison made between using older notation and different conventions in metrics used in theoretical physics, such as Minkowski and Bjorken-Drell metrics.
- A later reply decodes the notation, suggesting it represents the target, projectile, and final state, but this interpretation is not universally accepted.
- Another participant notes that the notation remains common in nuclear physics, indicating that it is still in use today.
Participants express differing views on the relevance of older notation in current research, with some defending its use while others question it. There is no consensus on the exact implications of the notation regarding projectiles and targets.
There are unresolved assumptions about the definitions of terms used in the notation and the context in which it is applied. The discussion reflects varying levels of familiarity with the notation and its historical context.
