Register to reply
Magnetic flux and C-EMF
by Miyz
Tags: cemf, flux, magnetic
Share this thread:
Drakkith
#19
Feb2-13, 10:46 AM
Mentor
Drakkith's Avatar
P: 11,501
Quote Quote by Miyz View Post
Ok, after reviewing my friend statement. He didn't mean that C-EMF will not be generated, but it will. However, it will not have maximum effect.
His statement:
"Its not that the lines need to be parallel but the field applied to the solenoid must be perpendicular to the cross sectional area of the solenoid to have maximal effect. So that if there is a flux in the solenoid to start with the applied field will then be parallel to that field."
Does this make any sense? And is it true? "Maximum effect" part?
I'm still reviewing the basics, so I can't determine anything.
I'm actually not certain. I'm barely a beginner myself. I think he's saying the field lines need to run perpendicular to the coil's wires and parallel to the field lines that run through the coil if you have current flowing. The only way for that to happen is to have your magnet inside the coil, so that would make sense that it would have the maximum effect since your magnet literally couldn't get any closer if it wanted to.
Miyz
#20
Feb4-13, 03:11 AM
P: 200
I think so too.
Register to reply
Related Discussions
What is magnetic flux and magnetic flux density? Please keep it simple. Introductory Physics Homework 3
Differences between Electromagnetic flux and magnetic flux Classical Physics 3
Hall Effect Magnetic Flux Sensor in very Strong Magnetic Fields Electrical Engineering 17
Magnetic flux density vs magnetic flux Classical Physics 5
Magnetic fieldstrength, magnetic flux, magnetic flux density General Physics 0
