Two Spin 1/2 Particles: Stot=0 Outcome?
The discussion revolves around the measurement outcomes of two spin 1/2 particles that are in a total spin state of Stot=0. Participants explore the implications of measuring the spin components of the particles, particularly focusing on how the measurement of one particle affects the other.
  • One participant suggests that measuring the spin component S1z of the first particle results in a loss of total spin information, leading to a 50% chance for the second particle's measurement outcome.
  • Another participant questions the necessity of distinguishing between the two particles, emphasizing the importance of eigenstates of angular momentum.
  • A participant asserts that if the total spin is zero, the system must be in the singlet state, prompting inquiries about the possible outcomes of measuring S1z.
  • One participant challenges the idea that the measurement of S1z results in independent outcomes for S2z, stating that the measurements are correlated.
  • Another participant expresses confusion about why the system remains in the singlet state after measuring S1z, seeking clarification on the implications of such a measurement.
  • A later reply discusses the influence of measurement on particle correlations, mentioning scenarios where the interaction between measurements can affect outcomes, depending on the distance and conservation of angular momentum.
  • Another participant elaborates on the final states after measurements, indicating that measuring S1z influences the result of S2z, which is a common aspect of quantum mechanics.
Participants express differing views on the implications of measuring one particle's spin on the other, with some asserting that measurements are correlated while others propose that the total spin information is lost. The discussion remains unresolved regarding the exact nature of the outcomes following the measurements.
Participants reference the singlet state and its implications for measurement outcomes, but there are unresolved questions about the effects of measurement on particle correlations and the conditions under which these effects manifest.
K8181
I have a hypothetical situation that I am trying to work through...
Say there are two spin 1/2 particles, and the system is known to be in a total spin state of Stot=0. An observer comes along and determines the first particle to have a spin component (S1z) of hbar/2. Now say another observer comes along and measures the z component for the second particle (S2z). What is the outcome?
My solution is this: I believe the Stot information is lost when the first observer measures S1z, so that then there is a 50% chance of the second observer measuring hbar/2, and a 50% chance for -hbar/2.
Is this right?
Thanks very much.
Well, the problem is, how do you distinguish between the two particles ?
I found the problem in a book, and it says that the first observer is trained to measure particle one, and the second is trained to measure particle two. I don't think distinguishing between them is the crux of the problem. I am more concerned about eigenstates of angular momentum and that sort of thing. The experiment is some fictitious scenario invented to illustrate a point.
If the total spin is zero, then there's only one spin-state the system can be in: the singlet [tex]|0 0\rangle[/tex] configuration. What are the possible outcomes when you measure [itex]S_{1_z}[/itex]?
Is this right?
No. The spin measurements of the two particles are correlated. Can you write the overall singlet state in terms of combinations of the individual S1z and S2z states? (I'm making the same point made by Galileo.)
I guess my confusion is...why is the particle still in the singlet state once the measurement of S1z has been carried out?
K8181 -- You are somewhat correct. The measurement of one of the particles can influence the other if they are in a bound state in which case the interaction between measurement and particle 1 also can perturb particle 2. For example, consider a helium atom with the electrons in a total spin 0, S-state. If we use a spin 0 probe, then the matrix elements for any spin flip will be zero. On the other hand, if we use a spin 1 probe, spin flip is possible, and the initial spin correlation will not survive the interaction. (I'm assuming the the probe comes in as an S wave, so the total probe angular momentum is = probe spin.)
If, as in EPR, the two electrons travel well away from their source, then their correlation will be unchanged by measurement.
So, it all depends on whether angular momentum is conserved by the measurement, and/or whether the two are sufficiently distant to preclude radiation, or whatever, from measurement 1 going to measurement 2 prior to the second measurement.
Regards,
Reilly Atkinson
Local measurement of singlet state
The answer is clearly given by quantum mechanics for this measurement :
Operators :
-measurement operator in A is S1z
-measurement operator in B is 1 (identity operator, since you don't measure in B)
Final state=Eigenstates
-final state in A is |+> or |->
-final state in B is [tex]|\phi>= \left(\begin{array}{c} cos(\phi)\\ sin(\phi)\end{array}\right)[/tex]
Hence the final state after a measurement of S1 without measuring in B is either [tex]|+>|\phi>[/tex] or [tex]|->|\phi>[/tex] with some (by quantum mechanics) given probablitities...
However if you measure S1z and S2z, then the final state is |+-> or |-+>...so measuring or not S2z influence the result, a usual fact in quantum mechanics
I don't know if this is clear...?
  • · Replies 24 ·
