D^2T/dx^2 + d^2T/dy^2 + d^2T/dz^2 = C
  • Context: Graduate
  • Thread starter Thread starter timsea81
The discussion focuses on solving the three-dimensional heat conduction equation, specifically the equation D^2T/dx^2 + d^2T/dy^2 + d^2T/dz^2 = C, where C is derived from constant heat generation due to electrical resistance, expressed as C = q'''/k. The user successfully applies the method of separation of variables for the homogeneous case but encounters challenges with the non-homogeneous case. A proposed solution involves finding a particular solution of the form T = τ + Ax^2 + Bx^2 + Dx^2, leading to the equation 2A + 2B + 2D = -C, which can be solved using boundary conditions.
  • Understanding of partial differential equations (PDEs)
  • Familiarity with the method of separation of variables
  • Knowledge of boundary value problems in heat conduction
  • Basic concepts of thermal conductivity and heat generation
  • Study the method of separation of variables in depth for PDEs
  • Explore boundary condition applications in heat conduction problems
  • Learn about particular solutions for non-homogeneous PDEs
  • Investigate the role of thermal conductivity (k) in heat transfer equations
Mathematicians, physicists, and engineers working on heat transfer problems, particularly those involved in thermal analysis and modeling in three dimensions.
timsea81
I'm trying to solve the heat conduction formula in 3 dimensions when there is constant generation from electrical resistance q'''. This creates a constant C on the right hand side that is equal to q'''/k.
T=T(x,y,z)
d^2T/dx^2 + d^2T/dy^2 + d^2T/dz^2 = C
I found a solution using separation of variables for when the right hand side equals 0, but it doesn't work with a non-zero constant on the right, because you end up with:
X'''/x + Y'''/y + Z'''/z = C/XYZ
I think I got it, maybe. I can solve the homogeneous equation:
d^2τ/dx^2 + d^2τ/dy^2 + d^2τ/dz^2 = 0
and then assume the particular solution to have the form:
That makes
d^2T/dx^2 + d^2T/dy^2 + d^2T/dz^2 = 0 + 2A + 2B + 2D,
So 2A + 2B + 2D = -C
and I can use boundary conditions to find A, B, and D
You need to start with a particular solution ([itex]Cx^2/2[/itex] will suffice, but if you expect your solution to have certain symmetry properties then it might be worth looking for a particular solution which shares those properties) and then add complementary functions to satisfy the boundary conditions.
  • · Replies 20 ·
  • · Replies 0 ·
