Measuring Protein Concentration w/ Microtiter Plate: Lid On or Off?
  • Thread starter Thread starter sobored
    Plate
When measuring protein concentration using a microtiter plate, it is established that the lid should typically be removed during the optical density (OD) measurement in a microplate reader. This practice allows for more accurate readings, as covering the plate may interfere with light transmission. Users are encouraged to conduct their own tests to compare results between covered and uncovered plates for validation.
  • Understanding of optical density (OD) measurements
  • Familiarity with microtiter plates and their applications
  • Knowledge of microplate reader operation
  • Basic principles of protein concentration measurement
  • Conduct experiments comparing OD readings with and without microtiter plate lids
  • Research best practices for using microplate readers
  • Explore the effects of light interference on optical measurements
  • Learn about different types of microtiter plates and their impact on assay results
Researchers, laboratory technicians, and anyone involved in protein assays or optical density measurements using microtiter plates.
sobored
when i measure the protein concentration using a microtiter plate. should i have the plate covered with its lid when i put it in the microplate reader to measure the OD?
thanks.
Biology news on Phys.org
We usually do not use the cover when reading plates using a microplate reader. You can always do a test to see if there any difference between reading from a plate with cover and without cover
thank you.
  • · Replies 20 ·
  • · Replies 31 ·
