Find a vector function that represents the curve of intersection of the two surfaces
by Litcyb
Tags: help a noob, homework help, homework questions
Litcyb
Litcyb is offline
#1
Jan31-13, 02:00 AM
P: 35
Find a vector function that represents the curve of intersection of the two surfaces:
The cone z = sqrt( x^2 + y^2) and the plane z = 1+y.
2. Relevant equations
3. The attempt at a solution
This problem can be solved as following using x as the parameter.
x^2+y^2 = z^2 = (1+y)^2 = 1+2y+y^2. => x^2 = 1 + 2y.
x=t; y = (t^2-1)/2; z = 1+(t^2-1)/2 = (t^2+1)/2
My question is, what if we use y as the parameter,
i get ,
y=t, x=(2t+1)^(1/2) z=t+1,
is this answer also correct?
Phys.Org News Partner Science news on Phys.org
Going nuts? Turkey looks to pistachios to heat new eco-city
Space-tested fluid flow concept advances infectious disease diagnoses
SpaceX launches supplies to space station (Update)
Dick
Dick is offline
#2
Jan31-13, 09:03 AM
Sci Advisor
HW Helper
Thanks
P: 25,168
Quote Quote by Litcyb View Post
i get ,
Sure, with the proviso that it only represents part of the curve. For example, points with negative values of x won't appear in the second parametrization (where you also should specify t>=(-1/2)). You'd need the x=(-(2t+1)^(1/2)) solution as well to get them all.
Register to reply
Related Discussions
2D Vectors - Addition and Subtraction of Successive Displacement Vectors Introductory Physics Homework 20
Unit tangent vectors, Normal vectors, and Gradients Calculus & Beyond Homework 0
find unknown constant of two vectors to make vectors perpendicular to each other? Calculus & Beyond Homework 8
Vectors: Given two vectors, find a vector that bisects the angle between the two give Calculus & Beyond Homework 10
Position Vectors, Velocity Vectors, and Acceleration Vectors Introductory Physics Homework 3
