I think all electric heaters are equally efficient
  • Context: High School
  • Thread starter Thread starter jalak7
    Electric
The discussion revolves around the efficiency of electric heaters, specifically whether all electric heaters are equally efficient due to the nature of electricity converting to heat. Participants explore the implications of energy ratings, safety considerations, and personal comfort in heating solutions.
  • One participant argues that all electric heaters are equally efficient since nearly 100% of the electricity used converts to heat, excluding minimal electromagnetic radiation.
  • Another participant supports this view, explaining that electric heaters typically use resistive heating elements, which efficiently convert electrical energy to heat.
  • Concerns about safety are raised, suggesting that factors like electrical shock and fire hazards should be prioritized when selecting a heater.
  • A participant mentions that while heaters can deliver warmth, the method of heat distribution (radiant vs. fan vs. convector) affects comfort levels in a room.
  • One comment humorously suggests that personal comfort is subjective and can be influenced by psychological factors, referencing polar bears as an example.
  • Another participant points out that electromagnetic radiation does contribute to temperature readings, depending on exposure to light.
Participants express differing views on the importance of energy ratings for heaters, with some asserting that all electric heaters are fundamentally efficient while others emphasize the relevance of safety and comfort factors. The discussion remains unresolved regarding the best choice of heater.
Participants highlight various factors that could influence heater performance and safety, including electrical ratings, the type of heating element, and personal comfort preferences. There is no consensus on the necessity of energy star ratings for electric heaters.
jalak7
My wife and I think two different things, and I would like to see which of us is correct. I'm only somewhat knowledgeable of physics, so I may be wrong.
We need an electric heater for a bedroom. My wife says we should be an energy star heater. But I'm saying that it doesn't matter which heater we buy because almost 100% of the electricity used will turn into heat (excluding some tiny amount of electromagnetic radiation). So I think all electric heaters are equally efficient.
Who is right, my wife or myself?
Science news on Phys.org
Basically your right, electric heating in the most cases use the simple fact that when a current is passing through a resistor it heats up the resistor.
Most heaters use a coil of special metal alloy like nichrome, which has a desirable material durability and electrical resistance to convert the passing current into heat.
I don't think there will or can be much difference in terms of "energy star" for heaters.Ofcourse there are other factors you should look like the safety of the device and rated power.Also thing to check is does the heater rated power suits the one your ac outlet in your room can provide.I assume were not speaking of that big of a heater here but just in case , because sometimes people get like 2kw or more rated big heaters and then use a tiny little power cable to feed them which results in overload of the wire and can result in fire and /or short circuit between the wires.Sometimes the wall outlet gets considerably hot even with smaller power over a longer period of time.Well all you need to do is to pay attention to the ratings of a specific heater.If it says only watts on the datasheet, then divide those watts with your ac mains voltage and you will arrive at the amperage.In ac there are the power factor also to be considered in terms of calculating the real watts to amps but in your case that is not that important as it is a resistive load.
Speaking of energy star it is more used in semiconductor devices like switch mode power supplies , tv sets, and other equipment.
in other words in devices that present non linear (capacitive, inductive,etc) loads to the mains ac.A heaters coil makes a purely resistive load which is the most efficient one in terms of consumed power to output power.
Hope that helps.
jalak7,
You and your wife have the chance to “do your homework” since you have internet access. Safety ought to be your first priority. I suggest you evaluate electrical shock hazards, fire hazards, and burn hazards before choosing your heater. Here are a few websites that can guide your selection of electric space heaters:
http://www.consumerreports.org/cro/space-heaters.htm
Picking the right space heater
Various models can deliver warmth, but not necessarily savings
http://www.bostonglobe.com/business...mer-reports/oJnMtKl3cCUnxS0xyDcLrN/story.html
5 Great Portable Electric Space Heaters
http://www.treehugger.com/culture/5-great-portable-electric-space-heaters.html
Stay warm, and Cheers,
Bobbywhy
When you 'pour heat' into a room, it doesn't always end up making you feel 'cosy'. It's important that the heat gets to you. Radiant heaters can be great against your face but can give you a cold back and cold feet. Fan heaters make a bit of a noise but will heat a room evenly and relatively quickly (for a given power). Convectors under windows will reduce draughts and heat the room evenly and quietly but it takes time.
There is no 'right answer' to this. (You can't beat insulation and draught proofing for long term good value, of course.)
You're screwed. Just tell here she's right even though she isn't.
Or buy her some warm slippers and a thick dressing gown. Feeling warm is all in the mind - look at Polar Bears, for instance.
good yoke #sophiecentaur :D Maybe it's because polar bears have the skin and feather as thick as two bulletvests? Or am I just fooled by the illusion of being cold. :D
Ofcourse how you feel has a lot to do with your emotions , oh just by the way speaking of positive imagery for those who haven't seen Dave Chappelles thoughts about it...
:D:D
Electromagnetic radiation does contribute to the temperature. If you have your thermometer in the shade vs in the light with the same ambient air temperature, one will read higher than the other. Thats because the light contributes to the temperature.
Of course whether you personally are going to feel that temperature is another question, one that was addressed a few posts up.
just pack your bags and move to the tropics
Somehow interesting that a thread about household heaters has more responses than an average thread about nuclear physics or electric engineering :D
@greswd moving to the tropics doesn't solve the problem as you would have to use more power to cool your products in the fridge and air conditioning to cool down your head so that you could be able to think and make a meaningful thread or response here on PF.But in that case looks like your already writing from tropics :D:D
just a yoke.no offense.
  • · Replies 66 ·
9K
  • · Replies 32 ·
