Hv(jω) Magnitude Calculation in non-standard circuits.
The discussion focuses on calculating the magnitude and phase response of non-standard AC circuits that do not conform to typical filter types such as Low-Pass, High-Pass, or Band-Pass. The circuit in question includes an AC source with internal resistance, a capacitor, an inductor, and a load resistance. The equivalent Thevenin impedance is derived using the formula: [(jωL)-(ω²LCZa) + Za] / [1 + jωCZa], while the Thevenin voltage is expressed as Vthev = Vsource * (Zc / (Zc + Za)). The final load voltage is calculated using Vload = Vsource * (Zc * Zload) / [(Zc + Za)(Zthev + Zload)].
  • Understanding of Thevenin's theorem
  • Familiarity with complex impedance calculations
  • Knowledge of AC circuit analysis
  • Ability to manipulate complex numbers
  • Study complex impedance in AC circuits
  • Learn about Thevenin's equivalent circuits
  • Explore methods for calculating magnitude and phase response
  • Investigate numerical methods for circuit analysis
Electrical engineers, circuit designers, and students studying advanced AC circuit analysis who need to understand non-standard circuit responses.
DabaDuBa
I was wondering how to calculate the magnitude and phase response of any circuit that is neither Low-Pass,High Pass nor Band-Pass. I am asking this because i haven't found anything relevant in any textbooks so far , since the only use standard filters.
e.g an AC circuit consisting of an AC source with internal resistance A , capacitor C , inductor L , resistance B (the load) such that :
Zc||(Zb + ZL)
Following the commonly suggested methodology , the equivalent Thevenin impedance would be :
[ (jωL)-(ω*ω*L*C*Za) + Za ] / [ 1 + j*ω*C*Za ]
and the Thevenin Voltage :
Vthev = Vsource * ( Zc / (Zc + Za))
Vload = Vthev *Zload / ( Zload + Zthev)
Therefore :
Vload = Vsource *( Zc * Zload) / [ ( Zc+Za)*(Zthev +Zload)]
where Hv(jω) is the coefficient in front of Vsource which will be quite complicated.
How can we calculate its magnitude and phase response ?
Thank you
Zc||(Zb + ZL)
Therefore :
Thank you
This is just a simple network analysis problem. To do the calculation, just substitute the numerical values for all those impedances (Za, Zb, Zc, Zthev, Zload, etc.) into the expression and work out the arithmetic. The arithmetic will, of course, involve complex numbers.
12K
  • · Replies 32 ·
14K
