Program for a game similar to rock-paper-scissors
  • Thread starter Thread starter sandy.bridge
    Game Program
The discussion revolves around programming a game similar to rock-paper-scissors, specifically called proton-neutron-electron (P, N, E). Participants are focused on coding syntax issues, game logic, and the rules governing the outcomes of player choices.
  • Homework-related
  • One participant describes their implementation of the game and requests help with syntax errors in their code.
  • Another participant suggests replacing assignment operators with equality operators in conditional statements.
  • A participant shares a corrected version of the code that works, but still seeks clarification on the original issues.
  • There is a discussion about the rules of the game, particularly regarding ties and the outcomes based on player choices, with some participants questioning the logical consistency of the rules.
  • One participant proposes a more structured approach to the if statements to simplify the logic of determining the winner.
Participants express differing views on the logical consistency of the game's rules, particularly concerning ties and outcomes. There is no consensus on whether the rules as stated are coherent or if they could be simplified.
Some participants note that the rules provided in the assignment may not align with typical game logic, leading to confusion about the expected outcomes. The discussion highlights the importance of clear rule definitions in game design.
sandy.bridge
I'm writing a program for a game similar to rock-paper-scissors. It is called proton-neutron-electron (P, N, E). There are two players. In the event of a tie, player 2 wins
P1 denotes player 1, P2 denotes player 2, P = proton, N = neutron, E = electron. P1P means player 1 picks proton.
There are 9 possibilities. Here they are:
P1P + P2P = P2 wins
P1P + P2N = P1 wins
P1P + P2E = P1 wins
P1N + P2P = P2 wins
P1N + P2N = P2 wins
P1N + P2E = P2 wins
P1E + P2P = P1 wins
P1E + P2N = P2 wins
P1E + P2E = P2 wins
Here is what I have written in the compiler; it does not work. I am not looking for another solution, I would just like to know where I went wrong in my syntax.
PHP:
	char user1, user2;
	bool A, B, C, D, E, F;
	count << "Player 1, please enter your move: ";
		cin >> user1;
		count << "Player 2, please enter your move: ";
		cin >> user2;
	if (user2 = 'P')
		A = true;
	else
		A = false;
	if (user2 = 'N')
		B = true;
	else
		B = false;
	if (user2 = 'E')
		C = true;
	else
		C = false;
	if (user1 = 'P')
		D = true;
	else
		D = false;
	if (user1 = 'N')
		E = true;
	else
		E = false;
	if (user1 = 'E')
		F = true;
	else
		F = false;
	}	if ((B&&D)||(C&&D)||(A&&E)||(B&&F))
			count << "The winner is player 1!";
	else
			count << "The winner is player 2!";
	return 0;
The way that it is set up now always results in P1 winning and I can't see why. Thanks in advance!
You could start by replacing all = with == and see what happens?
That didn't work.
I managed to just do as such:
PHP:
#include <iostream>
using namespace std;
int main() {
	char user1, user2;
			count << "What move P1? ";
			cin >> user1;
			count << "What move P2? ";
			cin >> user2;
			if (((user1 == 'P')&&(user2 == 'N'))||((user1 == 'P')&&(user2 == 'E'))||((user1 == 'N')&&(user2 == 'P'))||((user1 == 'E')&&(user2 == 'N')))
					count << "Player 1 is the winner!";
			else
					count << "Player 2 is the winner!";
			return 0;
I'd still like to know what I was doing wrong for the first part.
Can you post the changed code that you tried but didn't work?
PHP:
    char user1, user2;
        cin >> user1;
        cin >> user2;
    if (user2 == 'P')
        A == true;
    else
        A == false;
    if (user2 == 'N')
        B == true;
    else
        B == false;
    if (user2 == 'E')
        C == true;
    else
        C == false;
    if (user1 == 'P')
        D == true;
    else
        D == false;
    if (user1 == 'N')
        E == true;
    else
        E == false;
    if (user1 == 'E')
        F == true;
    else
        F == false;
    else
    return 0;
This didn't work ^^^^
PHP:
#include <iostream>
int main() {
	char user1, user2;
			cin >> user1;
			cin >> user2;
			else
				}			return 0;
This did work ^^^
Note: '==' is a logical operator which you use, for example, in an 'if' statement to test if a certain condition is true:
if (user1 == 'P') {'some calculations'}
If you wish to assign a certain value to a variable, then the following statement is used:
user1 = 'P';
Ah yes, that was where my issue was. Works now! Thanks! I will obviously just use the other one though because it is much shorter.
1. P1P + P2P = P2 wins
2. P1P + P2N = P1 wins
3. P1P + P2E = P1 wins
4. P1N + P2P = P2 wins
5. P1N + P2N = P1 wins << P2 should be the winner here[/color]
6. P1N + P2E = P2 wins
7. P1E + P2P = P1 wins
8. P1E + P2N = P2 wins
9. P1E + P2E = P2 wins
I added numbers to the rules for easier identification.
Your rule 5 violates what you said earlier about ties going to player 2.
Can you summarize the rules any better than in the table?
It looks like proton beats neutron (rules 2, 4) and electron beats neutron (rule 6) sometimes, but neutron beats electron sometimes (rule 8). Is that also a mistake?
In rock paper scissors, there is a simple set of rules: rock covers (beats) paper, scissors cut (beat) paper, and paper covers (beats) rock. Is there a similar, simple rule here that you didn't mention? If so, it would make your logic much simpler.
Yeah, I noticed that as well. There doesn't seem to be any logicality with it, but that is how the table was given in the assignment. At that point I just made sure the algorithm obeyed the table.
PHP:
	         P1 plays P  	P1 plays N	         P1 plays E
P2 plays P	     P2	             P1	              P2
P2 plays N	     P1	             P2	              P1
P2 plays E	     P1	             P2	              P2
I redid the indentation in your code so that the lines didn't scroll so far to the right.
sandy.bridge said:
Code:
#include <iostream>
int main()
  char user1, user2;
  cout << "What move P1? ";
  cin >> user1;
  cout << "What move P2? ";
  cin >> user2;
  if (((user1 == 'P')&&(user2 == 'N')) ||
      ((user1 == 'P')&&(user2 == 'E')) ||
      ((user1 == 'N')&&(user2 == 'P')) ||
      ((user1 == 'E')&&(user2 == 'N')) )
    cout << "Player 1 is the winner!";
  else
    cout << "Player 2 is the winner!";
  return 0;
This did work ^^^
Then you have an error in post 1. According to the table below, if both players play a neutron, P2 wins.
PHP:
P2 plays P	     P2	             P1	              P2
P2 plays N	     P1	             P2	              P1
P2 plays E	     P1	             P2	              P2
Oops! I just edited that thanks.
Instead of one if block with a large condition, I would write three if blocks in which I check what player 1 has. I have implemented the first of these if blocks, and have added comments to suggest what the logic is.
Code:
if (user1 == 'P')
  if (user2 == 'P')
  else
else if (user1 == 'N')
  // Player 2 wins only if player 1 has 'P'
else // user1 == 'E'
  // Player 1 wins only if player 2 has 'N'
  • · Replies 29 ·
  • · Replies 33 ·
