| New Reply |
Sidebands in AM Transmission |
Share Thread | Thread Tools |
| Feb1-13, 02:38 PM | #18 |
Sidebands in AM Transmissionhttp://users.ece.gatech.edu/~vkm/nii/node35.html Yes, the sideband frequencies are actually transmitted along with the carrier (the actual carrier average power does not change during AM modulation). http://www.technology.heartland.edu/...modulation.ppt |
| Feb1-13, 04:32 PM | #19 |
But the easiest way to show how AM produces sidebands is to start with a formula which describes Amplitude Modulating a carrier wave with angular frequency ωc with a cosine modulating signal of frequency ωm does: A =A0Cos(ωct)(1+Bcos(ωmt)) A0 is the mean amplitude of the carrier and B is the Modulation Index - the depth of modulation. This will give you the familiar picture of a carrier amplitude varying in level, as the modulation varies, and around its unmodulated amplitude. (The envelope picture). That expression can be transformed, using the basic multiple angle trig identities into A = A(cos(ωc) + Bcos((ωm+ωc)/2 + B((ωm-ωc)/2) which shows you that the AM signal can be described as a carrier and a pair of sidebands that have up to half the amplitude of the carrier. You don't need to do any Fourier analysis for this - in the simple case, it's just a bit of simple trig. And, if you don't like trig, then steer clear of Fourier - it's harder still. |
| Feb1-13, 05:45 PM | #20 |
My god what have I gotten myself into!? This is why I don't ask questions! I get amazing answers that show me how ignorant I really am! I think I'll take some of the advice I see you give around the forum Sophie. I'll hold off on running until I can walk in this area. (Or in my case, roll over and crawl first)
Thanks guys! I don't quite understand, but I'm definitely better off than I was before. Nsaspook, thanks for the links, they were pretty helpful! |
| Feb1-13, 07:35 PM | #21 |
| Feb2-13, 07:48 AM | #22 |
It's a bit simplistic to say that our hearing receives the FT. The cochlea does a time varying frequency analysis. Both time and frequency domains are perceived. FT is just a mathematical process relating the two domains yet is often quoted in cases where it just isn't that straightforward. Windowing is very relevant in practice.
| Feb2-13, 10:20 AM | #23 |
http://clas.mq.edu.au/perception/psy...ng_theory.html |
| Feb2-13, 04:55 PM | #24 |
I think the big problem arises when we attempt to describe what the brain / sensor combination 'actually does' with its input, using the same terms that we use to describe how we would make a recording or perform signal analysis using technology.
The same difficulty arises when describing our visual perception, where the temptation is to think that the camera-like structure of the eye's hardware gives the remotest clue about how we make a conscious model of our surroundings in our heads. I think this thread would be better to stick to the basics of signal processing, where we do have a chance of understanding what goes on. At least the Maths is appropriate and fits the evidence. |
| Feb2-13, 06:43 PM | #25 |
| Feb3-13, 06:19 AM | #26 |
Actually, I should qualify that a bit. The Cochlea and the interconnections on the retina are examples of just those structures. |
| New Reply |
| Thread Tools | |
Similar Threads for: Sidebands in AM Transmission
| Transmission Lines | Electrical Engineering | 4 | ||
| ehv dc transmission | Electrical Engineering | 5 | ||
| HIV transmission | Biology | 5 | ||
| Power Transmission | Engineering, Comp Sci, & Technology Homework | 2 | ||
| Transmission | Advanced Physics Homework | 5 | ||
