Using Projectile motion to find the distance above a wall
The problem involves analyzing the projectile motion of a tennis ball served at an angle below the horizontal, with the goal of determining the distance the ball clears a net of a specified height. The context includes variables such as the initial speed of the ball, the angle of projection, the height from which it is served, and the distance to the net.
  • Participants discuss the equations of motion for both the horizontal and vertical components, questioning the use of tangent in the calculations. There are attempts to derive the time it takes for the ball to reach the net and to express the height of the ball at that moment.
Some participants have provided guidance on the correct equations to use, suggesting a focus on sine and cosine rather than tangent. There is acknowledgment of confusion regarding the initial height of the ball and the need for clarification in the equations being used. Multiple interpretations of the problem are being explored, with no explicit consensus reached yet.
There is an ongoing discussion about the assumptions made in the equations, particularly regarding the initial height of the ball and the relevance of certain trigonometric functions. The level of the physics problem is also questioned, indicating a potential mismatch in expectations.
PensNAS
1. Homework Statement
During a tennis match, a player serves the ball at a speed s, with the center of the ball leaving the racquet at angle θ below the horizontal at a height y0. The net is a distance d away and has a height h. When the ball is directly over the net, what is the distance between them? Express your answer in terms of the given variables and the gravitational acceleration g.
2.Relevant equations
y=dtanθ-d^2(g/(2(scosθ^2))
3.The attempt at a solution
y=dtanθ-d^2(g/(2(scosθ^2))-h
I assumed the equation would give the y at the distance,d. Subtract the height of the net and that would be the distance by which the tennis ball would clear the net. As it turns out, that is not correct. I am a little confused. Any help would be appreciated!
Write equations for x(t) and y(t). Tan(θ) plays no part in this. Try sines and cosines instead ... use the x equation to determine the time T it takes for the ball to reach the net and the y equation to determine the height of the ball = y(T) when it reaches the net, then answer = y(T) - h.
I set x=scos(θ)t and y=ssin(θ)t-0.5gt^2. Solving for t with the x equation I got t=x/scosθ. Plugging that into the y equation I got the same equation of y=dtanθ-d^2(g/(2(scosθ^2)). I tried simplifying that some more and got (2(s^2)sin(2θ)d-gd^2)/2(s^2)cos(θ)^2. It still is not right and I don't know how else to simplify that ungodly fraction:)
You got the x equation right and I assume you solved for t correctly (let x = d). Call that t = T.
Your y equation is almost right also, it's missing an initial value of y = y(t=0). When you add it you will have an expression for y(T) where t=T is the time the ball is over the net.
I do owe you one apology: tan(theta) does appear in the y equation after all, since T = d/s*cos(theta). But derive it correctly.
By the way, is this high school physics?
  • · Replies 39 ·
  • · Replies 21 ·
  • · Replies 42 ·
