| New Reply |
Heat Exchanger Heat load calculation |
Share Thread | Thread Tools |
| Jan31-13, 11:43 PM | #1 |
i need to calculate heat load(Q) of a shell and tube heat exchanger.In this heat exchanger problem gives the following datas
tube side(water) Avg flow rate=115 m3/hr@3.5 kg/cm2,density=990 kg/m3,Δt=5 c,cp=4186 j/kg c shell side(hot fluid) Avg flow rate=120 m3/hr@4.5 kg/cm2,density=1100 kg/m3,Δt=15 c,cp=3767 j/kg c when i use eqn Q=mCpΔt i couldn't get both shell side and tube side heat transport equal. can any one help to solve this..?? thanks |
| New Reply |
| Tags |
| heat exchangers, heat load, heat transfer |
| Thread Tools | |
Similar Threads for: Heat Exchanger Heat load calculation
| Heat transfer with a plate heat exchanger. | Mechanical Engineering | 4 | ||
| Heat Transfer in a heat exchanger. | Engineering, Comp Sci, & Technology Homework | 9 | ||
| heat exchanger output temperature calculation | Introductory Physics Homework | 1 | ||
| Is the overall heat transfer coefficient constant for a certain heat exchanger? | Advanced Physics Homework | 0 | ||
| Heat exchanger calculation | Engineering, Comp Sci, & Technology Homework | 2 | ||
