Mind blown by mechanical systems (2nd order)
The discussion revolves around the dynamics of mechanical systems, specifically focusing on second-order differential equations related to a mass-spring-damper system. The original poster presents a problem involving the derivation of equations of motion for a mass connected to a spring and damper, questioning the role of the natural length of the spring and the definition of relative velocities in the context of damping forces.
  • The original poster attempts to derive the equations of motion but expresses confusion regarding the natural length of the spring and the definition of velocities in relation to the damper. Participants question the meaning of "vk" and discuss the implications of reference frames on velocity definitions.
Participants are actively engaging with the original poster's questions, providing clarifications about damping forces and the nature of relative velocities. Some guidance has been offered regarding the interpretation of velocities in the context of the system, but no consensus has been reached on all aspects of the problem.
There is mention of potential confusion stemming from different reference frames for velocity, which may affect the understanding of the damping force in the system. The original poster also notes that their teaching assistant did not clarify these reference frames, contributing to the uncertainty in the discussion.
hihiip201
B, K, M
1. xs(t) -----spring ----mass-----damper-----fixed, derive DE for x of mass
given :2. F - > M -----spring-------damper ---- fixed in series, derive the DE for velocity of spring
1. ma = -k(x-xs) - B(v)
But I don't understand, why aren't we taking the natural length of the spring into account?
2. no idea, I have the solution and it says that damping force is B(v(t) - vk) , but I have no idea what v has anything to do with damper, the relative velocity vb should just be vk - 0 to me but the textbook and the homework solution suggest otherwise.
Velocity relative to what? You haven't said what "vk" means.
HallsofIvy said:
Do you not understand what a "damper" is? It is a way of introducing friction into the equation, so "damping" (reducing) the motion. Often it is thought of a some sort of hydraulic piston moving through water, but ordinary friction as an object moves over the floor will do. The whole point is, and I am sure that this is given in your text, that we can take the friction force to be proportional to, and in opposite direction to, the speed- the faster the object moves, the more the friction opposes the motion. The friction force is typically [itex]\alpha |v|[/itex] where [itex]\alpha[/itex] is some negative number. As long as your object is moving in one specific direction, you can remove the absolute value and put the sign into the constant.
I do believe I understand what a damper is, but if you look at my system (indicated in series). I can't see what v(t) of mass has anything to do with the damper.
since the damping force = B(relative velocity between each end)
in this case, right end is fixed, left end is the spring's velocity, so I just can't see why Damping force fb which is equal to fk in this case is not B(vk).
oh gosh...maybe that's the key, my TA didn't say anything about the reference frame of the velocity, and multiple times they have displacement that have different references...
but i do believe v is the velocity of mass relative to the inertial frame of wall. and vk should be the spring velocity of the spring(right hand side of spring, left hand side of damper) relative to the inertia frame of the wall.
Got it! vk is actually just v of the right side of spring - vm. so that makes sense that vm cancel out.but the reason why they used vk is because they want to replace it with the elemental equation 1/k * dfk/dt in the de to develop a 2nd order differential equation for the velocity.
thanks HallsofIvy.
  • · Replies 16 ·
  • · Replies 21 ·
