| New Reply |
What exactly is the reactive centrifugal force (split) |
Share Thread |
| Feb10-13, 05:21 PM | #137 |
Recognitions:
| Feb10-13, 05:42 PM | #138 |
Mentor
| Feb10-13, 09:25 PM | #139 |
Recognitions:
If you are talking about real forces, the turntable is trying to grab the outer block and change its velocity. The surface of the turntable is accelerating inward underneath the block. If the friction between the outer block and turntable is not enough to provide the force needed to accelerate both blocks to keep them on the turntable, the turntable surface accelerates away from blocks which continue their inertial motion. They would be accelerated somewhat by the kinetic friction force between the turntable and block until they left the surface. The only real force that is apparently outward is the reaction force of the block on the turntable. If the turntable and spindle was sitting on a frictionless you would be able to see the block and spindle both rotate about a vertical axis through their common centre of mass. The block would exert a force on the turntable that causes the centre of mass of the turntable to rotate about the common centre of mass (which is between the spindle and the block). Since it is fixed to the earth, the reaction force of the block is exerted on the earth which undergoes a much smaller rotation. AM |
| Feb10-13, 10:17 PM | #140 |
Mentor
This line of conversation is still irrelevant. Regardless of the validity of your reasons for disliking it, the term exists. You cannot wish it away, nor can you reason it away. |
| Feb10-13, 10:41 PM | #141 |
Recognitions:
AM |
| Feb10-13, 10:44 PM | #142 |
Mentor
But in some cases it clearly does. |
| Feb10-13, 11:43 PM | #143 |
Recognitions:
We have beaten this issue to death. So let me recap where I think we differ.
I think we fundamentally disagree on what third law action and reaction pairs are. It is easy in a collision of free bodies analysed from an inertial reference frame. One body accelerates in one direction and the other accelerates in the opposite direction - changes in momentum are equal and opposite. Or, if a rocket sends rocket gas in one direction, the rocket recoils in the other. These are third law action/reaction pairs. No problem. The problem occurs when you do not have a system that defines an inertial reference frame. For example, you say that the reaction to the centripetal force supplied by mechanical means is the force that the body being accelerated applies to the body or part of the body that is supplying the accelerating force. I say that is simply an inertial effect and the real reaction/action pairs are the centripetal force that the rotating body experiences and the centripetal force that this body exerts on the rest of the system as both rotate about their common centre of mass. Similarly, the third-law pair in applying a force to a box with my hand (with me standing on the earth) is the force I exert in the opposite direction on the earth. The change of momentum of the earth that results is equal and opposite to the change of momentum of the box. You seem to be saying that it is the force of the box on my hand. I say that force of the box on my hand is simply an inertial effect - a pseudo force really because it can never be associated with an acceleration. In my view, this is where we disagree. We can argue all we like about Newton's third law but we will continue to disagree because we take somewhat different view on the application of the law to these situations. AM |
| Feb11-13, 07:15 AM | #144 |
Mentor
1) You have been unable to produce any textbook or online reference which expresses the third law mathematically in terms of momenta, while I have produced several that express it mathematically in terms of forces. 2) You have also been unable to produce any textbook or online reference which even clearly expresses it verbally in terms of momenta. 3) You have been able to find one reference which is, by your own admission, quite unclear so a small part of it can be construed in a way that at least doesn't contradict your position. However, even that reference contradicts your position when you read the whole reference instead of taking that small part out of context. |
| Feb11-13, 12:27 PM | #145 |
Recognitions:
The explanation of law III continues To summarize, action and reaction forces are always equal and opposite in pairs, but they don't necessarily cause equal and opposite changes of momentum if the motion of the two bodies is constrained in some other way. That explains why the changes in momentum of the horse and the stone are not equal and opposite, of course. Reformulating classical mechanics in terms of "Mason's laws of motion" is fine by me, but don't mis-attribute Mason's laws to Newton where they are different. |
| Feb12-13, 02:04 AM | #146 |
Recognitions:
"Newton’s explanation starts out talking about forces and pressures, speaks of obstructing and advancing “progress,” and finally ends up talking about what appears to be momentum. I’ll say right here that I am unimpressed with the clarity of Newton’s explanation. I go back and forth between thinking action/reaction should be read as the change in motion as opposed to being read as the thing that changes the motion. But rather than pick nits (and criticize an author who can’t defend himself), let’s zero in on what Newton seems most intent upon telling us in this, his third law of motion: there is a specific relationship between the changes in the motions of two interacting objects. Hence, this is a law of motion." In the simple situation of an astronaut pushing off from a space ship with his legs, the third law is demonstrated by the equal and opposite changes of momentum that result to the two parts of this inertial system (ie. astronaut and space ship). If you just apply the reciprocity of forces between the astronaut's feet and the surface of the space station, this does not explain the physics. You have to take into account what the feet and space station surface are connected to. You then have to take into account the masses of those bodies and the motions of the centres of mass of those bodies. Those are legitimate third law action/reaction pairs. They do not lose that quality simply because the centres of mass are not touching. There are a myriad of other forces (between different parts/atoms etc.) that we simply ignore because they are not important. AM |
| Feb12-13, 01:13 PM | #147 |
Mentor
In context, Newton's Principia does not support your approach, and I have yet to see any other scientific reference that does either. |
| New Reply |
Similar discussions for: What exactly is the reactive centrifugal force (split)
| G-Force and (possibly) Centrifugal force applied to the rotation of a car | Introductory Physics Homework | 0 | ||
| Reactive force on radiation | Classical Physics | 5 | ||
| Reactive Centrifugal Force | Classical Physics | 403 | ||
| Reactive centifugal force. | Classical Physics | 9 | ||
| Can gravitational force be reactive? | General Physics | 5 | ||
