| New Reply |
What exactly is the reactive centrifugal force (split) |
Share Thread |
| Jan31-13, 05:33 PM | #35 |
Recognitions:
What exactly is the reactive centrifugal force (split)AM |
| Jan31-13, 05:55 PM | #36 |
Recognitions:
Newton's explanation of the third law uses both the concept of a force and of change in motion. He begins by talking of a body pressing on another, the latter pressing back on the first (a finger pressing a stone and the stone pressing back on the finger), and then says: If a body impinges upon another, and by its force changes the motion of the other, that body also (because of the equality of the mutual pressure) will undergo an equal change, in its own motion, toward the contrary part. The changes made by these actions are equal, not in the velocities but in the motions of the bodies; that is to say, if the bodies are not hindered by any other impediments. For, as the motions are equally changed, the changes of the velocities made toward contrary parts are reciprocally proportional to the bodies.It is interesting that Newton speaks of "bodies ... not hindered by any other impediments". One can argue whether he was equating action with "force on an otherwise unimpeded body", but that is not an unreasonable interpretation. With respect to the astronaut space-station example, the third law says that a body undergoing centripetal change in motion due to contact with another unimpeded body causes that other body to have an equal change of motion in the opposite direction. So if we are talking about the astronaut undergoing a centripetal change in motion due to contact with the space station/other astronaut (taken as one body), the third law "reaction" is a change in motion of the space station/other astronaut in the opposite direction. That change in motion always points to the centre of rotation. AM |
| Jan31-13, 06:16 PM | #37 |
Recognitions:
[itex]\vec{F}_{12} + \vec{F}_{32} + \vec{F}_{13} + \vec{F}_{23} + \vec{F}_{21} + \vec{F}_{31} = 0[/itex] You get that from the first law. If [itex]\vec{F}_{12} + \vec{F}_{32} = 0[/itex] and if 2 is not accelerating then either [itex]\vec{F}_{12} = \vec{F}_{32} = 0[/itex] or there are other forces acting on 2. In that case you would have to write: [itex]\vec{F}_{12} + \vec{F}_{32} + \vec{F}_{13} + \vec{F}_{23} + \vec{F}_{21} + \vec{F}_{31} + \sum F_{i(ext)} = 0[/itex], which is again just the first law. Take a simpler case of a magnet (body 1) and an iron bar (body 2) stuck to it by the magnet's magnetic force. The total force of the magnet on the bar is 0 and the total force of the bar on the magnet is 0. If it were otherwise, there would be acceleration. AM |
| Jan31-13, 06:33 PM | #38 |
Recognitions:
AM |
| Jan31-13, 06:38 PM | #39 |
Recognitions:
AM |
| Jan31-13, 06:45 PM | #40 |
Recognitions:
AM |
| Jan31-13, 09:14 PM | #41 |
Mentor
Also, this may be a translation error. Other translations are pretty clear on the standard interpretation. "Whatever draws or presses another is as much drawn or pressed by that other. If you press a stone with your finger, the finger is also pressed by the stone. " http://www.marxists.org/reference/su.../en/newton.htm Do you have any mainstream scientific reference that clearly supports your unorthodox stance? To ensure clarity, it would be best if it expressed the law mathematically. I.e. the usual version is something like [itex]F_{12}=-F_{21}[/itex] but your version would be something like [itex]dp_1/dt = - dp_2/dt[/itex]. Can you find a reference that actually expresses the third law that way? Here are some clear references for the usual way: http://en.wikipedia.org/wiki/Newton%....27s_third_law http://www.phy6.org/stargaze/Snewton3.htm http://www.ck12.org/concept/Newtons-...s-Third-Law%2F |
| Jan31-13, 09:20 PM | #42 |
Mentor
| Feb1-13, 01:18 AM | #43 |
Needless to say that even if you were right, it would be still irrelevant. It would not change the fact that the contact force Frcf acts centrifugally on the wall. |
| Feb1-13, 01:33 AM | #44 |
But even if you were right about what he initially meant centuries ago in his Latin prose, it would still be irrelevant. Laws of physics are often generalized over the course of time. Today we have a 3rd law that applies to forces regardless of accelerations. |
| Feb1-13, 03:18 AM | #45 |
| Feb1-13, 06:14 AM | #46 |
Recognitions:
"With respect to the astronaut space-station example, the third law says that a body undergoing centripetal change in motion due to contact with another unimpeded body causes that other body to have an equal change of motion in the opposite direction. So if we are talking about the astronaut undergoing a centripetal change in motion due to contact with the space station/other astronaut (taken as one body), the third law "reaction" is a change in motion of the space station/other astronaut in the opposite direction. That change in motion always points to the centre of rotation."Here is a simple question: If the reaction force to the centripetal acceleration of astronaut 1 is a centrifugal static force (ie it does not result in any contrary change in motion of the thing that is accelerating astronaut 1) what is the force that causes the centripetal acceleration of the centre of mass of the space station/other astronaut? AM |
| Feb1-13, 06:40 AM | #47 |
Recognitions:
The third law says that the action (which we can take to be A's action on B and C) is accompanied by an equal and opposite reaction (the action of B and C on A). So we can say that the change in motion of A is accompanied by equal and opposite changes in motion of B and C. This is true at all times before during and after the interaction. AM |
| Feb1-13, 06:40 AM | #48 |
[itex]\vec{F}_{12} = \vec{F}_{32} = 0[/itex] The fact that 2 is not accelerating is what tells us that [itex]\vec{F}_{12} + \vec{F}_{32} = 0[/itex]. |
| Feb1-13, 06:42 AM | #49 |
Sorry, you don't get to decide how people divide the system into parts. In my example there are 3 objects: station & 2 astronauts. This is a perfectly valid way to analyze the scenario. So deal with it, and don't try to change it. |
| Feb1-13, 07:00 AM | #50 |
As I said, in a three-body problem, there are 6 two-body interaction forces: [itex]\vec{F_{12}}, \vec{F_{21}}, \vec{F_{13}}, \vec{F_{31}}, \vec{F_{23}}, \vec{F_{32}}[/itex] where [itex]\vec{F_{IJ}}[/itex] means the force of object [itex]I[/itex] on object [itex]J[/itex]. If it's a static situation, the sum of the forces on each object is zero. So we conclude: [itex]\vec{F_{12}} = -\vec{F_{32}}[/itex] [itex]\vec{F_{13}} = -\vec{F_{23}}[/itex] [itex]\vec{F_{21}} = -\vec{F_{31}}[/itex] Then Newton's third law (interpreted in terms of equal and opposite forces) implies [itex]\vec{F_{12}} = -\vec{F_{21}}[/itex] [itex]\vec{F_{13}} = -\vec{F_{31}}[/itex] [itex]\vec{F_{23}} = -\vec{F_{32}}[/itex] These 6 equations have the solution [itex]\vec{F_{12}} = \vec{F_{21}} = \vec{F_{13}} = \vec{F_{31}}= \vec{F_{23}} = \vec{F_{32}} = 0[/itex] But I don't see how you can get that conclusion without invoking the force version of the 3rd law. |
| Feb1-13, 07:03 AM | #51 |
Recognitions:
Every atom in that space station/2 astronaut example is accelerating. There are a gazillion tension forces. The total force on each atom is the atom's mass multiplied by its centripetal acceleration. AM |
| New Reply |
Similar Threads for: What exactly is the reactive centrifugal force (split)
| G-Force and (possibly) Centrifugal force applied to the rotation of a car | Introductory Physics Homework | 0 | ||
| Reactive force on radiation | Classical Physics | 5 | ||
| Reactive Centrifugal Force | Classical Physics | 403 | ||
| Reactive centifugal force. | Classical Physics | 9 | ||
| Can gravitational force be reactive? | General Physics | 5 | ||
