Register to reply
What exactly is the reactive centrifugal force (split)
by A.T.
Tags: centrifugal, force, reactive, split
Share this thread:
A.T.
#55
Feb1-13, 09:12 AM
P: 3,932
Quote Quote by Andrew Mason View Post
Ok. It is a centrifugal force that has as its only physical effect the acceleration of the centre of mass of the rest of the system toward the centre of rotation.
Wrong and irrelevant. It can have other physical effects, like creating a dent in the wall. But the physical effects of the force are irrelevant to the fact that it acts centrifugally.
Static?!!! You can't be serious.
Yes, static. Nothing moves in the rotating frame of my scenario.
It is rotating.
Not in the rotating frame.
stevendaryl
#56
Feb1-13, 09:19 AM
Sci Advisor
P: 1,969
Take the simplest example of the three masses in a straight line: 1, 2, 3. None are accelerating. So:
(1)[itex]\vec{F}_{12} + \vec{F}_{32} = 0[/itex] and
(2)[itex]\vec{F}_{21} = 0[/itex] and
(3)[itex]\vec{F}_{23} = 0[/itex].
But [itex]\vec{F}_{23} = -\vec{F}_{32}[/itex] and [itex]\vec{F}_{21} = -\vec{F}_{12}[/itex]
So that means:
[itex]\vec{F}_{12} = \vec{F}_{32} = 0[/itex]
The same thing applies if they are arranged in a triangle or any other shape.
AM
No, it doesn't. Dale gave a counterexample. Here's a different one: You have three particles 1, 2, and 3. For simplicity, let them be in a straight line, so we only need consider the x-component of the forces. Let
[itex]F_{12} = 0[/itex]
[itex]F_{32} = 0[/itex]
[itex]F_{13} = 1[/itex]
[itex]F_{23} = -1[/itex]
[itex]F_{31} = 2[/itex]
[itex]F_{21} = -2[/itex]
That satisfies Newton's first law, but not the third.
Andrew Mason
#57
Feb1-13, 02:23 PM
Sci Advisor
HW Helper
P: 6,654
Quote Quote by A.T. View Post
A dent in the wall would require a momentary reduction in the centripetal force being applied by the space station to the astronaut (at the given rotational speed) and a corresponding reduction in the astronaut's reaction force. If you say this reaction force is a centrifugal force it is very strange that it only causes an outward effect when it is reduced.
You were posting as I was editing. I added:
It is rotating. Everything is accelerating. We use the inertial frame to analyse forces. The absence of apparent acceleration in the non-inertial frame is not real. Why are you even referring to this? This makes it very difficult for the student to distinguish between the apparent centrifugal force and the real reaction force (which you say is a static centrifugal force and I say is a non-static centripetal force).
We don't analyse real forces in the rotating frame.
AM
DaleSpam
#58
Feb1-13, 03:19 PM
Mentor
P: 16,999
There is no need for a reduction in the centripetal force in order to cause a dent. You are again taking one specific scenario and making a mistaken generalization.
Yes, we do. We also analyze fictitious forces there, but real forces are not ignored.
I note that you have not found a reference that writes a clear mathematical expression corresponding to your version and calls that the third law. All you have is an ambiguous translation that cannot be said to clearly contradict your approach.
A.T.
#59
Feb1-13, 03:36 PM
P: 3,932
What is strange about this?
When you sand on a table, you exert a downwards force on the table. When that downwards force starts deforming the table downwards, there eventually will be a momentary reduction in that downwards force. Do you find it strange to call it a downwards force, because it creates a downwards effect when it is reduced?
Who is "we"? I show the forces in both frames in the diagram.
Andrew Mason
#60
Feb1-13, 05:19 PM
Sci Advisor
HW Helper
P: 6,654
Quote Quote by DaleSpam View Post
I suppose someone could soften the floor so the astronaut made a dent. Is that what you mean? The process of making the dent still involves an increase of the distance from the centre of rotation, which reduces the centripetal force and the reaction to that force.
I gave you Newton's explanation of the third law. You don't accept that? The translations from the latin are correct. Any ambiguity is Newton's not the translator's.
Acceleration is the second time derivative of the body's displacement vector relative to an inertial point. If you use as your reference a non-inertial point whose acceleration is constantly changing, how would you measure real acceleration?
AM
Andrew Mason
#61
Feb1-13, 05:31 PM
Sci Advisor
HW Helper
P: 6,654
Suppose the top 10 cm of the floor of the space station was softened so that the astronaut's feet and centre of mass move 10 cm farther from the centre and cause a 10 cm dent in the floor. Is this dent caused by the reaction force to centripetal acceleration or is it the inertial effect of the reduction in centripetal force due to the softening of the floor? There is a big difference: one is a real force and the other is not. If one calls both forces (the real reaction force of the astronaut on the space station and the fictitious centrifugal force observed only in the rotating frame) centrifugal it gets very confusing. Even Newton was confused by centrifugal force.
AM
A.T.
#62
Feb1-13, 05:32 PM
P: 3,932
There is no ambiguity in physics books today. The law deals with forces and accelerations are irrelevant.
A.T.
#63
Feb1-13, 05:50 PM
P: 3,932
Is this dent caused by the reaction force to centripetal acceleration force
Yes. But don't confuse forces and accelerations.
Andrew Mason
#64
Feb1-13, 07:24 PM
Sci Advisor
HW Helper
P: 6,654
Why is it not caused simply by the astronaut's inertia due to the inability of the floor to provide the needed centripetal acceleration? Why is it so fundamentally different if that 10 cm of the floor just momentarily dissolved?
By the way, I put it that way because you insist that one can have a force that produces no acceleration as a third law reaction to one that does produce acceleration. There is nothing wrong or confused in saying the force is related to an acceleration.
AM
DaleSpam
#65
Feb1-13, 07:38 PM
Mentor
P: 16,999
No, the centripetal force is [itex]mr\omega^2[/itex], it increases as the distance from the center increases.
Then Newton was ambiguous. I read it and to me it seems to be talking about forces. You read it and to you to you it seems to be talking about changes in momentum. It does not clearly support your position (nor does it clearly support mine).
EDIT: Actually, after having read the entire quote in context it seems quite clear that Newton is not supporting your view. The part of the quote you cited is not the law, but the last of three examples. First he gives the "action-reaction" formulation of the law. Then he clearly talks about forces, not accelerations, in an example of a finger pressing a stone and second example of a horse drawing a stone. Then he introduces a third example, this one clearly indicating the special case of two bodies with no other forces acting so that the force is equal to the change in momentum (by his second law). In that case your formulation is equivalent to the usual formulation, but in all of the other examples he clearly intended the usual formulation, not yours.
That is why I prefer sources that use math which is clear and unambiguous. All of those that I have seen clearly contradict your position. Can you provide any unambiguous (with math) support for your position? I provided unambiguous (with math) support for mine, so I don't think it is unreasonable to require the same from you.
What is "real acceleration"? I would measure "coordinate acceleration" as the second time derivative of my coordinate location. I would measure "proper acceleration" with an accelerometer. I don't know what "real acceleration" is.
DaleSpam
#66
Feb1-13, 07:42 PM
Mentor
P: 16,999
It is caused by the centrifugal reaction force. It is certainly not caused by anything related to "the reduction in centripetal force" since the centripetal force does not reduce but instead increases.
Andrew Mason
#67
Feb1-13, 10:17 PM
Sci Advisor
HW Helper
P: 6,654
??? The reaction force completely disappears if the centripetal force disappears, which is what happens when the floor completely dissolves. So how can the reaction force cause the outward motion?
I know it seems counter-intuitive, but with no external torque the centripetal force decreases as r increases. We see this from the fact that gravity, which supplies the centripetal force for orbiting bodies, varies as 1/r^2.
AM
Andrew Mason
#68
Feb1-13, 10:39 PM
Sci Advisor
HW Helper
P: 6,654
Yes, but ω decreases as 1/r (L = constant) so the centripetal force decreases as 1/r: [itex]F_c =mr\omega^2 = L^2/mr[/itex]
It is an interesting question, I'll grant you that.
I found this commentary which wrestles with this very issue.
I know what you are saying but the real problem I have is that Newton talks about force in his first two laws but talks about action and reaction in his third and does not mention force. The first two laws are quite straight forward and unambiguous. But the third is not, due to his use of undefined terms. That said, we should not be too critical of any confusion Newton may have had or caused by his statement of this law. Newton's laws are a truly remarkable achievement when one considers the state of physical science at the time.
I don't think it is a matter of contradicting "my position" because I am just saying that Newton's third law is a statement about conservation of motion (momentum) and I don't think conservation of momentum can be contradicted.
"Real acceleration" is a non-zero second derivative with respect to time of a body's displacement from a fixed point in an inertial reference frame. It does not matter what inertial reference frame you select. It is the same in all (in Galilean relativity).
AM
A.T.
#69
Feb2-13, 01:58 AM
P: 3,932
Why is it not caused by the Big Bang due to the fact that without the Big Bang there would be no astronaut and space station in the first place? You can always construct endless cause-effect chains. But usually we consider forces acting on the object as the direct cause of the objects deformation. Therefore only a force acting on the wall can be a direct cause of the wall's deformation.
But keep in mind that the whole causation reasoning about forces is often more fuzzy intuitive mythology, than physics. It doesn't affect the quantitative results. The action doesn't cause the reaction in the 3rd law. They both happen simultaneously, and physics just says they are equal but opposite. The same is true for net force and acceleration in the 2nd law. Although we often say that the net force causes the acceleration, they both happen simultaneously, and physics just says they are proportional.
A.T.
#70
Feb2-13, 02:06 AM
P: 3,932
By insisting on your interpretation of Newtons 3rd you are contradicting modern mainstream physics. That is because the mainstream interpretation is more general than your interpretation. So you are basically saying that Newtons 3rd doesn't apply to all those cases, where mainstream physics says it does apply. See also my remarks in post #145.
A.T.
#71
Feb2-13, 02:16 AM
P: 3,932
L = constant
Here is your error. Only the L of the entire system must be constant. The L of the astronaut doesn't have to be constant.
DaleSpam
#72
Feb3-13, 09:13 PM
Mentor
P: 16,999
We are talking about the force ON the floor (the reactive centrifugal force), so of course it disappears if the floor completely dissolves. The deformation of the floor is in the outward direction which requires a force on the floor in the outward direction*. This force is the reactive centrifugal force.
*EDIT: actually, on further thought I realized that I am making an incorrect generalization from statics. What is required is a shear stress in the radial direction and/or a tension in the circumferential direction. In this specific case the stress is caused, in part, by the reactive centrifugal force, but it is not a general requirement.
You are taking one specific case and making an incorrect generalization. In this case, we are dealing with a massive space station, not a hula hoop. The ω of the space station is nearly independent of the astronaut's r, even in the absence of an external torque. Thus, the formula I posted (F=mωēr) is the correct one for this situation. The centripetal force increases with increasing r.
Again, you are taking one specific case and making an incorrect generalization. In this case, we are not dealing with gravity and a 1/rē force, we are dealing with material deformation which essentially follows Hooke's law (a force proportional to Δr) up to the point where you start getting plastic deformation (a force independent of r).
Register to reply
Related Discussions
G-Force and (possibly) Centrifugal force applied to the rotation of a car Introductory Physics Homework 0
Reactive force on radiation Classical Physics 5
Reactive Centrifugal Force Classical Physics 403
Reactive centifugal force. Classical Physics 9
Can gravitational force be reactive? General Physics 5
