| New Reply |
"Picture" of electro-magnetic vector potential in 1+1 dimension spacetime? |
Share Thread |
| Feb2-13, 06:49 PM | #1 |
I'm trying to model the electro-magnetic vector potential, does the following come close for 1 + 1 dimension spacetime? See sketches below.
Consider an elastic string, under tension, between two fixed points A and B that lie on the z axis. Let the distance between points A and B be large. Let the motion of the string in the x and y directions be given by ψ_x(z,t) and ψ_y(z,t). The string is such that both ψ_x(z,t) and ψ_y(z,t) satisfy the wave equation ψ(z,t),tt = c^2ψ(z,t),zz. Now confine the motion of the string so that it moves freely on the surface of a cylinder of radius r, see below. Now let the position of the string be given by θ(z,t), with θ(A,t) and θ(B,t) = 0, and let θ(z,t) = 0 when the string is at rest. Define an orientation on the cylinder so we know which direction positive θ is. Now let charge density ρ(z,t) interact with the constrained string above in the following way, where ever we have positive (negative) charge density there is a perpendicular force on the string in the positive (negative) θ direction. The magnitude of the force in the θ direction on a segment of the string from z to z + dz is proportional to the charge density at z times dz. See below. The 1 + 1 dimensional vector potential A_0 will go like θ. the electric field will go like θ,z and A_z will go like θ times the velocity of the charge? Let there be two separated and localized charge densities, positive and negative, that act on the string in the manner above, see below. I think the 3 + 1 dimensional version of the above follows in a straight forward way. Thanks for any help or suggestions! |
| New Reply |
Similar discussions for: "Picture" of electro-magnetic vector potential in 1+1 dimension spacetime?
| Can I express "stationary spacetime" and "static spacetime" in this way? | Special & General Relativity | 8 | ||
| "Spacetime has No Time Dimension" | General Physics | 20 | ||
| Concept of an "area vector" when finding magnetic flux | Classical Physics | 4 | ||
| Green's functions for "vector potential" in curved SPACE | General Physics | 4 | ||
| "partial integration" of gradient vector to find potential field | Calculus | 7 | ||
