MatLab - Raising each component of a matrix
by Aseeb
Tags: component, matlab, matrix, raising
Aseeb
Aseeb is offline
#1
Feb4-13, 09:19 PM
P: 3
I am in great need of the syntax that tells MatLab to raise the component of a vector to any power.
I also need to know the syntax that outputs the time to perform the calculation.
Thank you
Phys.Org News Partner Science news on Phys.org
Going nuts? Turkey looks to pistachios to heat new eco-city
Space-tested fluid flow concept advances infectious disease diagnoses
SpaceX launches supplies to space station (Update)
jhae2.718
jhae2.718 is offline
#2
Feb4-13, 10:14 PM
PF Gold
jhae2.718's Avatar
P: 1,153
If you mean raising the each component of the vector to the same power, e.g. you want ##{\boldsymbol x} ^ n = [x_0^n, x_1^n, \ldots, x_m^n]^T##, then you can use:
% x = some vector
x .^ n;
For timing, you can use:
t = cputime;
% do some operations here
elapsed = cputime - t;
fprintf('Elasped time: %.2f s\n', elapsed);
Aseeb
Aseeb is offline
#3
Feb4-13, 10:32 PM
P: 3
Thank you, Sir.
kreil
kreil is offline
#4
Feb5-13, 10:24 AM
kreil's Avatar
P: 518
For timing, you can also use 'tic' and 'toc' as follows:
X = 1:1000;
tic
X2 = X.^2;
toc
Elapsed time is 0.006004 seconds.
In general, you can put any code snippet between the two tags. 'tic' always marks the beginning of the timer, and 'toc' the end.
Register to reply
Related Discussions
Showing raising operator raising! Advanced Physics Homework 3
Linear Algebra - Raising a matrix to a power Calculus & Beyond Homework 2
Matrix help in MatLab, Not the simple matrix!! I have searched, found nothing! Math & Science Software 3
Raising/Lowering indices and matrix multiplication Special & General Relativity 9
matrix element (raising and lowering operators) Quantum Physics 4
