How many terms are needed for Fourier Isometry to be under 5%?
The discussion focuses on verifying the Fourier Isometry for the function f(t) = t over the interval [−π, π]. Participants calculated the sine coefficients, resulting in bk = (-2√π / k)cos(kπ), and confirmed that the series converges with the sum of squared coefficients given by Σbk² = 4πΣ(1/k²). To achieve an isometry error under 5%, 3 terms are necessary, while 5 terms are needed for an error under 3%, and 7 terms for under 1%. The mean squared error formula is essential for these calculations.
  • Understanding of Fourier Analysis and Fourier Series
  • Knowledge of orthogonal functions and their properties
  • Familiarity with convergence of series
  • Proficiency in calculating integrals and norms
  • Study the properties of Fourier Isometry in detail
  • Learn about the mean squared error in the context of Fourier Series
  • Explore the convergence criteria for Fourier Series
  • Practice calculating Fourier coefficients for various functions
Students and educators in mathematics, particularly those studying Fourier Analysis, as well as researchers and practitioners working with Fourier Series in applied mathematics or engineering fields.
kbooras
Hey guys. I just started a class on Fourier Analysis and I'm having a difficult time understanding this question. Any help would be much appreciated!
Verify that the Fourier Isometry holds on [−π, π] for f(t) = t. To do this, a) calculate
the coefficients of the orthogonal Fourier series from the orthogonal series representation, b)
calculate the sum of the squared coefficients, and c) Calculate the norm of the function as
∫ |f(t)|2 dt. They must be equal. How many terms in the Fourier series are necessary to have the isometry be under 5%? How many until you are under 3%, or 1%.
Since f(t) = t is an odd function, you only need to calculate the sine coefficients.
bk = 1/[itex]\sqrt{}π[/itex]∫f(t)dt
I solved for bk and got (-2[itex]\sqrt{}π[/itex] / k)*cos(k π)
Then I tried solving for the sum of bk ^2 but the series diverges, so now I'm stuck. Also, I'm not even sure what I'm trying to show for this problem.
No, the series doesn't diverge. Note that ##\cos(k\pi) = (-1)^k##. Then (assuming your formula is correct; I haven't checked),
$$b_k^2 = \frac{4\pi}{k^2}$$
and so
$$\sum b_k^2 = 4\pi \sum \frac{1}{k^2}$$
which converges. (To what is another question.)
I got it! Thank you very much for pointing that out jbunniii. I can't believe I forgot to square the k.
Now that I've shown the Fourier Series is an isometry, I need to determine how many terms in the Fourier series are necessary to have the isometry be under 5%. I think I have to use the mean squared error formula for this but I'm not quite sure. If anyone could point me in the right direction I would really appreciate it.
  • · Replies 16 ·
