Troubleshooting My Circuit Sensor: Is It Working?
The discussion focuses on troubleshooting a circuit sensor, specifically a strain gauge, built on a breadboard. Users emphasize the importance of understanding the sensor's mechanism, which operates as a variable resistor. To measure changes in resistance, it is essential to incorporate the strain gauge into a voltage divider or bridge circuit. Identifying the sensor's resistance values is crucial for successful implementation.
  • Understanding of strain gauge functionality
  • Knowledge of voltage divider and bridge circuit configurations
  • Ability to measure resistance values accurately
  • Familiarity with breadboarding techniques
  • Research strain gauge specifications and resistance values
  • Learn about voltage divider circuits and their applications
  • Study bridge circuit configurations for sensor measurements
  • Explore troubleshooting techniques for circuit sensors
Electronics enthusiasts, hobbyists building sensors, and engineers working with strain gauges and circuit design.
mremadahmed
I want to build my own circuit sensor.
I opened the digital scale.I built the circuit on breadboard.The sensor is silverish color in the picture.
I have completed my circuit on breadboard but don't know how will this sensor work.
Can someone tell me what is the mechanism of this specific sensor.Where will I put the pressure so that it will work.I did hit and trial method but it did not work.
Maybe my sensor is failed.
You really need to get things in the right order, I think. You first need to know the basics of how your transducer works and then make the electronics to suit it.
Afaik, most strain gauges work as variable resistors. See this link
You need to include this variable resistor in a voltage divider or, perhaps, a 'bridge' circuit to measure the change of resistance as the gauge is stretched. Clearly, the first thing to find out is the actual resistance values you are needing to deal with - either by measurement or by looking up the spec of the device if you can identify it by number / type.
9K
9K
  • · Replies 41 ·
