New Reply
The translational force on a piece of iron in a magnetic field
Share Thread Thread Tools
Feb9-13, 12:09 PM   #1
Ok so if there be a piece of iron in a uniform magnetc field B, what will be the force on the iron?
You can assume any variable you want, but i want to find the magnetic force that causes the iron pieces to move towards the magnet in terms of any variables, like it corss-sectional area, length, position etc.
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> A quantum simulator for magnetic materials
>> Atomic-scale investigations solve key puzzle of LED efficiency
>> Error sought & found: State-of-the-art measurement technique optimised
Feb9-13, 02:46 PM   #2
mfb
Mentor
The net force is 0. There might be a torque, depending on the orientation of the iron and its magnetic field (if present) and the external magnetic field.
You need a field which is not uniform to move magnets.
Feb9-13, 10:04 PM   #3
Quote by mfb View Post
Oops... sorry! i forgot that! what i really had in mind was the force exerted on the iron by a bar magnet.... in that case the field is not unifrom.... sorry for that bit of wrong info! Anyway, i plan to first find the pole strength that develops on either faces of the iron and then use F=sB, s=pole strength... So how do i get my s?
Feb10-13, 07:13 AM   #4
mfb
Mentor
The iron bar will get a magnetic field similar to the external field, and this multiplied with the gradient of the external field should give some reasonable estimate for the force.
http://en.wikipedia.org/wiki/Force_between_magnets
Feb11-13, 02:58 AM   #5
The iron bar will get a magnetic field similar to the external field[/url]
Isn't the field inside the iron bar B=μ(I+H) where H= magnetizing filed and I= intensity of magnetization?
But then what to do? I need to find the developed pole strengths first, right?
How do I do that?
Feb11-13, 12:15 PM   #6
mfb
Mentor
A magnet does not consist of two separate poles. If you know the magnetic field (and assume it is the same everywhere in the magnet), it is fine.
Feb11-13, 09:19 PM   #7
Tell me one thing.... to obtain the force on a magnetic material why should'nt I multiply the inensity B with the developed pole strength in the material (s)?
Have I got a misconception about these things? Please help me. I am absolutely at a loss now!
Feb12-13, 09:36 AM   #8
mfb
Mentor
I think it is a detour. It is possible, but you just multiply with things (like the volume) and divide by them again afterwards.
Feb12-13, 09:51 AM   #9
Ok... One more thing, does the developed pole strength at each end of the iron bar change with its position? I think the pole strength will keep varying as a function of the field the iron bar is in. Am I right?
By using the properties of the material, I got an equation for the pole strength. Its given by,
s=χBA/μ , where χ is the susceptibility of iron, B is the field it is kept in, A is its cross-sectional area and μ is the permeability of the surrounding medium. Is this correct?
Feb12-13, 02:54 PM   #10
mfb
Mentor
Right.
I would expect the length somewhere, too, but it could be true.
Feb12-13, 09:50 PM   #11
Well surprisingly enough, the length canceled when i equated the magnetizing field in terms of the moment and the volume. Here it is:
I=M/V=M/A.l=s.l.M^/Al=M^s/A
Then again, χ=I/H=Iμ/B... and then the above expression of the pole strength
New Reply
Thread Tools
Similar Threads for: The translational force on a piece of iron in a magnetic field
Thread Forum Replies
Can a magnetic field do work on a current-carrying piece of wire? Classical Physics 8
Why is the magnetic field around a piece of wire circular? General Physics 1
Magnetic Force on Iron General Physics 9
Behaviour of iron in magnetic field Introductory Physics Homework 10
Calculating the magnetic field of 3 piece wire Introductory Physics Homework 0
