Not hard If you know how (homework) I don't
  • Thread starter Thread starter mushhhy
    Hard Homework
The discussion revolves around a physics problem involving motion and forces, specifically focusing on concepts such as acceleration, mass, force, kinetic energy, work, and impulse. The original poster presents their calculations and seeks assistance in identifying errors and clarifying concepts related to the problem setup.
  • The original poster attempts to calculate various physical quantities but expresses confusion regarding the signs of kinetic energy and the application of the work formula. Some participants question the assumptions made about the angle in the work calculation and whether the mass should be expressed in Newtons.
Participants are actively engaging with the original poster's calculations, offering clarifications on the work formula and discussing the implications of the angle in the context of the problem. There is an ongoing exploration of the problem's details, but no consensus has been reached yet.
The problem is based on a classroom experiment involving a collision between two toy cars, with specific initial and final positions and times provided. The original poster indicates they are preparing for a test and seeks to understand the concepts better.
mushhhy
Does anyone out there have a few minutes to review a problem I worked out ?
I need to know where I am making errors and how to correct them
If you have a few minuted and are willing to help a fella out please reply ASAP
Here goes The problem states to find the following
1. Acceleration 5. Work
2. mass 6.the weight of three rayovac cells placed on the object
3. Force 7. momentum with and without cells
4. KE 8. Impulse upon collision
Trial 1 weight of object = 985.5 g .986 kg
Xi = 100cm ti = 0
Xf = 38cm tf = 4sec
I need velocity for accelartion v = d/ t = -.62 m/4s = -0.155 m/s
a = v / t = (0.155 m/s) / 4 s = -0.039 m/s^2
mass = w / g = 0.986kg / (9.8 m/s^2) = 0.101kg (why is ans. not in Newtons)
Force F = m x a =0.101kg x (-0.039 m/s^2) = - 2.59 N
KE = (1/2) m x v^2 = (1/2)(0.101kg)(-0.155 m/s)^2 = -0.024 J, (can J be -)
work W = (F cos 0) X = ? I am stuck here, the object is on a level surface I am thinking that (cos 90) is correct am I right ?
PLease any help will be appreciated I am trying to complete assignment and study for test. :eek:
I see that this post is being viewed but not answered,
Did I do something wrong or is there an error in the post
I could really use a little help with this problem
Is there anyone out there just make a post if you can read me is there anyone at home
Okay.What's the text of the problem...?
Daniel.
[tex]W=Fdcos(\theta)[/tex]
if the force is being applied horizontally, then [tex]\theta[/tex] would be zero
Work is force times distance times cos(theta). In this case, if the force is being applied horizontally, then theta=0 so... cos(0)=1 so work would just be W=F*d
:cry: Thank you
The problem was an experiment done in class, it is set up as a collision between two cars on a track. one stationary and one propelled by a fan.
Xi = 100cm, Xf = 38cm, ti = 0, tf =4s the rest of the problem is in my first post. If you need any further info let me know I will check back every few minutes. I am trying to figure out some other problems.
Thanks again
