New Reply
Conduction between two materials
Share Thread Thread Tools
Feb10-13, 08:38 AM   #1
When I have a metal object at 0 degrees and a plastic object at 0 degrees, the metal feels colder as heat is conducted away at a faster rate. The reason for that would be that the metal is a better conductor of heat so when my hand touches it, it can start vibrating more quickly than the plastic.
So does this mean that how fast heat gets conducted into another material depends on the warmer material? For example if the metal and plastic is at 60 degrees, when I touch them they should feel the same? Because now that heat is transferred to the hands, the rate of heat flow into the hand from the hotter object will be the same (since the kinetic energy of the metal and plastic particles is the same so they should have the same rate of heat transfer to the hand). Is this correct?
Thanks
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> Iron-platinum alloys could be new-generation hard drives
>> Lab sets a new record for creating heralded photons
>> Breakthrough calls time on bootleg booze
Feb10-13, 12:49 PM   #2
Recognitions:
Gold Membership Gold Member
Nope. The metal would feel warmer and conduct heat into your hand at a greater rate.
Not only is the metal able to conduct heat into your hand better, it is also able to conduct heat within itself better too, so it also replaces the heat lost at the point of contact with your hand at a greater rate than the plastic can.
Feb10-13, 04:19 PM   #3
Recognitions:
as, posted already, no; It depends on the temperature difference between materials and the conduction rate of the poorer conductor.
Feb10-13, 09:45 PM   #4
Quote by Drakkith View Post
Oh that's right! But if I were to touch it for a brief moment then they would feel the same? Or would the touch be too slow? Also what is the formula for this? Thanks
Feb11-13, 05:37 AM   #5
Recognitions:
Quote by sgstudent View Post
That depends on how brief. If brief enough you wouldn't feel anything. A little longer and the metal would feel hot while the plastic probably wouldn't.
Sorry, I don't know that one.
Feb11-13, 12:47 PM   #6
Recognitions:
Heat transfer is governed by a second order differential equation called the diffusion equation, and the key parameter governing the rate of transfer is the diffusivity. Wikipedia is a good starting point for this
http://en.wikipedia.org/wiki/Heat_equation
Heat transfer across the boundary between different media is a little more complicated. I can refer you to appropriate texts if you are interested.
New Reply
Thread Tools
Similar Threads for: Conduction between two materials
Thread Forum Replies
Materials Science vs. Materials Engineering Academic Guidance 6
Conduction and lossless materials Electrical Engineering 6
Conduction PDE Engineering, Comp Sci, & Technology Homework 0
Heat Conduction Classical Physics 14
radiation and conduction Introductory Physics Homework 5
