Need desparate help on this question concerning finding a positive integer
  • Context: Graduate
  • Thread starter Thread starter clueles
    Integer Positive
The discussion revolves around finding a positive integer \( n \) such that \( 40n \) is a fifth power, \( 500n \) is a sixth power, and \( 200n \) is a seventh power. Participants explore the mathematical implications of these conditions, including the use of modular arithmetic and systems of linear congruences.
  • Homework-related
  • One participant expresses confusion about how to approach the problem and requests assistance.
  • Another participant provides the prime factorization of \( 40 \), \( 500 \), and \( 200 \), and sets up congruences for \( x \) and \( y \) based on the conditions for \( 40n \) being a fifth power.
  • A participant seeks clarification on solving the congruences and how to substitute values back into the expression for \( n \).
  • One participant corrects an earlier statement about the powers and emphasizes the need to satisfy all equations simultaneously.
  • Another participant introduces the Chinese remainder theorem (CRT) as a potential method for solving the system of equations.
  • A later reply discusses the necessity of rewriting the equations in a specific form to apply the CRT effectively.
Participants generally agree on the need to solve the system of equations simultaneously, but there is no consensus on the specific methods or steps to achieve this. The discussion includes differing approaches to using the Chinese remainder theorem.
Participants have not fully resolved the mathematical steps required to find \( n \), and there are multiple interpretations of how to apply the Chinese remainder theorem to the problem.
clueles
fi have no idea what to do and i tried posting it on another forum and nobody replied so please help me! thank you so much!
find a positive integer n so that 40n is a fifth power (of an integer) 500n is a sixth power, and 200n is a seventh power, or explain why it is impossible to do so (hint: let x = e2(n) and y = e5(n) use the given assumptions about n to find systems of linear congruences that x and y must satisfy. you may leave n in terms of its canonical prime factorization. show as much work as possible
40 = 2^3 * 5, 500 = 2^2 * 5^3, 200 = 2^3 * 5^2.
For simplicity, assume n = 2^x * 5^y for some natural numbers x, y.
Then 40n = 2^(x + 3) * 5^(y + 1). If this is to be a fifth power, both exponents must be divisible by 5, i.e.
x + 3 == 0 (mod 5),
y + 1 == 0 (mod 5).
You can find similar requirements for 500n and 200n. Then you solve this system of equations.
Thank you for answering my question. I just need some clarification though. When you have the
x + 3 == 0 (mod 6),
y + 1 == 0 (mod 6).
do you solve the congruence x + 3 == 0(mod6) and then you solve the second y+1 == 0(mod6) and once you do you subsitute the remainder into the n = 2^x * 5^y
For the 500n = 2^(x + 2) * 5^(y + 3).
x+2 == 0(mod6)
y+3 ==0(mod6)
what happens when you solve all the equations how do you know what n would be if you have different numbers?
I made a mistake in my original post, 40n was supposed to be a fifth power. The equations need to be changed accordingly.
No. You must find x, y such that all six equations are satisfied /simultaneously/:
x + 3 == 0 (mod 5),
y + 1 == 0 (mod 5),
x + 2 == 0 (mod 6),
y + 3 == 0 (mod 6),
x + 3 == 0 (mod 7),
y + 2 == 0 (mod 7).
Have you heard about the Chinese remainder theorem? (This system can be solved without explicitely using the CRT though).
After you have found a solution, you plug it into n = 2^x * 5^y. That's how you find out what n "is" (but n is not uniquely determined, i.e. there are infinitely many n that will work. The original problem was to find /an/ n that worked, not all n).
Question again
how can you use the chinese remainder theorem if you have an x and y and you want to do it simulatenously?
Um, by first solving
x + 3 == 0 (mod 5)
x + 2 == 0 (mod 6)
x + 3 == 0 (mod 7)
using the CRT, and then doing the same to
y + 1 == 0 (mod 5)
y + 3 == 0 (mod 6)
y + 2 == 0 (mod 7).
to use the chinese remainder theorem wouldn't you have to rewrite the equation s for the x's as
x==-3(mod5)
x==-2(mod6)
x==-3(mod7)
so then we can rewrite it using the q's. and once we figure out what the general form of it the x would be the remainder of it
  • · Replies 17 ·
31K
