Creating a Equation to Destroy the Sun
  • Context: Undergrad
  • Thread starter Thread starter hgivens07
    Sun The sun
The discussion revolves around the hypothetical calculation of the energy required to destroy the Sun, inspired by a fictional context. Participants explore various aspects of energy, mass, and gravitational forces in relation to both the Sun and Earth, while considering the implications of such a scenario.
  • One participant seeks to derive an equation for the energy needed to destroy the Sun based on a known value for Earth, expressing uncertainty about the necessary calculations and assumptions.
  • Another participant suggests that disassembling the Sun would be complex, even if energy requirements were met.
  • A different participant raises the concept of gravitational binding energy, questioning the definitions of "kill" and "destroy" in this context and suggesting that the Sun will eventually self-destruct over time.
  • One participant acknowledges the usefulness of an equation provided by another, indicating that it met their needs despite their initial explanation being unclear.
  • Another participant notes that the energy output of the Sun over millions of years would be required to dismantle it.
  • A suggestion is made to consider smaller-scale scenarios, referencing a related webpage about destroying Earth.
Participants express various viewpoints on the feasibility and definitions surrounding the destruction of the Sun, indicating that multiple competing views remain without a consensus on the approach or calculations involved.
Participants highlight the need for careful definitions of terms like "destroy" and "kill," as well as the complexity of energy calculations involving gravitational forces and mass. There is also an acknowledgment of the long timescales involved in stellar processes.
hgivens07
Alright, Not the best at math and need help with find a equation for the amount of energy needed for destroying the sun. This isn't based on real life, based on a TV series and I'm nerdy enough to want to know how much energy it would take lol. I have a number for how much energy it would take to destroy the earth, so I'm hoping it would be easy enough to convert. Not sure what numbers you'll need, so I'm going to probably going to pot a few extra.
Energy needed to destroy Earth = x
Mass of Earth = 6 x 10²⁴ kg
Gravity of Earth = 1
Diameter of Earth = 12,756 km
Circumference of Earth = 40,000 km
Mass of sun = 330,000 kg times Earth's mass or (2×10^30 kg)
Gravity of sun = 28 times Earth's gravity
Diameter of Sun = 1.4×10^6 km
Circumference of the sun = 4,300,000 km
Energy needed to destroy sun = y
Again not trying to solve for "x", trying to solve for y.
So I'm assuming that since we have "x" the amount of energy needed to destroy earth, we can use that number along with the size of the earth, to determine the amount needed to kill something as big as the sun.
The reason I posted Circumference and Gravity is because there are 330,000 times as much mass on the sun then there is on eath, you have to push each of them 28 times as hard, and you have to spread your energy over a larger area, because not only is the sun more massive (mass) than the earth, but it is also much bigger(area) than the earth. plus, if you don't move the particles far enough, fast enough, it all just comes crashing back together, and you haven't accomplished your goal. It's highly possible that my logic is incorrect or I'm missing things, if so please let me know.
So I'm hoping I explained this good enough and it's really simple. If you need more numbers let me know, I'm willing to go find them. Just give some feed back if this time of equation is even possible, and I appreciate the time anyone takes to even read this let alone try to solve it.
Astronomy news on Phys.org
You might be interested in an approximation and the theory ;).
It would be tricky to disassemble the sun, however, even if the required energy is not an issue.
I was thinking in terms of gravitational binding energy too ... though the terms "kill" and "destroy" need more careful definition to be sure. How damaged is "destroyed"? Could you just wait? (The Sun is due to destroy itself in a bit... OK, a bit longer...)
Thank you that equation actually was exactly what I was looking for. Can't believe you were able to decphyer my horrible explanation. Thanks so much!
Note that it will take a couple million years of the sun's output to produce enough energy to take it apart.
Maybe you should start small first. There is a semi-related web page dedicated to destroying Earth.
  • · Replies 20 ·
  • · Replies 26 ·
  • · Replies 18 ·
